Motorola Mobility E51 MD7161-3 Quad Cordless Phone Logo
A
Anonymous Posted on Apr 02, 2014
HANDSET READS "SEARCHING" - Motorola Mobility E51 MD7161-3 Quad Cordless Phone
1helpful
Handset reads handset 3 want to delete this Panasonic handset
Question moved from Cellphones to Land Phones.
You can try just removing the batteries for 10 minutes. That may clear its memory. Or you can deregister and then reregister the handset.
https://www.google.com/search?q=HANDSET+READS+HANDSET+3+WANT+TO+DELETE+THIS+PANASONIC+HANDSET
Why does screen indicate "searching"?
The handset cannot communicate with its base.
When the handset cannot establish its secure (encrypted) radio
link with the base it is 'paired with' or 'registered' to, it will first
say "Connecting....", then it will display "Out of Range or No
Power at Base", then it settles at the infamous "Searching..."
display.
Although rare, the registration between base and handset can
become corrupted and lost so that we must de-register and
then re-register the pair.
First, ensure that power is 'on' at the base (a more common cause)
and the cradle will charge the handset, etc.
Second, be sure the handset battery is well charged as a weak battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
or it will display "Registration Failed"
DECT 6.0 cordless. Why won't it register the handset when placed on the base?
This could be several things.... the simplest is that a weak
handset battery can interfere with registration. Or,
does the handset display say "Connecting..." or
"Searching...." or "Out of Range / no power at base ..." ??
In these cases the handset is registered to another base and
must be de-registered before it can be registered again.
after a few seconds the display will say:
press [SELECT]
display reads "Place in base..." and it should be ready to
register.
2answers
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Handset reads "searching"
The reason the handset says "Searching" is because it can not find its Base Station. What handset works with a notebook? I had not heard of such a thing.
2helpful
Hi My phone battery died and I recharged it. Now it is not recognizing the base and keeps searching.
Press and hold the end key, then while holding the end key, press and hold the # key. After 3 or 4 seconds the handset will beep and ask if you want to deregister the handset, select "Base unavailible" and confirm. Then the handset should read "Handset not registered". Place it on the base charging cradle and it should register.
66helpful
Uniden dect 6.0 display reads searching
Hi there, try this. Press and hold th eend key on one of the handsets, while holding the end key, press and hold the # key. After 3 or 4 seconds tha thandset should beep and read deregister Handset and underneath that "Base Unavailible". Select base aunavailible and confirm. Then tha thandset should read "Handset not registered, place handset on base" Once you place the handset in the bace cralde it should register in 5 - 10 seconds or so. then you should be good to go.
1helpful
2answers
Phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
3helpful
2answers
Handset display reads "searching". No dial tone. No response.
I am sure you have solved this problem by now. For others who might face the same problem...just unplug the batterry of the handset and plug it in..wow it works!!:))
Top Motorola Mobility Lands Phones Experts
Ngoro
john h
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
