Televison & Video Logo
A
Anonymous Posted on Apr 02, 2014
TWO FAINT BLACK VERTICAL LINES IN MIDDLE OF SCREEN
5 Related Answers
Anonymous
  • Posted on Oct 01, 2008
SOURCE: Faint Black Line down the middle of TV
how do you send all white picture to tv from computer?
Justin Washburn
  • 116 Answers
  • Posted on Dec 11, 2008
SOURCE: black vertical lines on flat screen
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Anonymous
  • 3 Answers
  • Posted on Jan 13, 2009
SOURCE: vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Anonymous
  • 1779 Answers
  • Posted on May 03, 2009
SOURCE: Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
roety
Eric Rotmil
  • 587 Answers
  • Posted on Aug 19, 2009
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Toshiba 32sl410u have 2 vertical lines on screen
Likely a shop repair but:
Either a bad board (main, or power or even a inverter board)
Worst case if Black line and thick would be the panel (screen unit) which would be fatal but is not likely if lines not black.
6helpful
2answers
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
10helpful
2answers
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
2helpful
Faint vertical lines on my samsung lcd 1080
hi
this is the problem caused by 3 main issues
1.colour wheel
2.cathode ray tube
3.jungle ic on D-board
check it..//thank u
please rate it
Black vertical bands in screen. Started as faint shodows now dark
Replace the ribbin cables that connects to the lcd panel. don't have part #
2answers
Black vertical lines on lcd screen
Has Bad LCD Panel hope its under warranty.
Black vertical lines on printed pages
check the "photoconductor unit" (pg 37 in the Maintance manual)
ours was doing it with the magenta and saw a faint 'scratch' on the roller. will attempt to replace and report back if this fixes it.
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
