When i start computer loggings application stops working & takes too long
SOURCE: vista home basic is not recognizing the zte usb modem fffd
Try a System Restore
if not work then usb has been damged
SOURCE: vista - football manager series
just right click on ur game icon and go to compatibility mode and enable the winows xp mode or enable the run as administrator mode... after that apply and click on ok.. and run ur game....
SOURCE: Microsoft Windows Vista Home Premium
Basically, your error comes from a program that may not be compatible with Vista. Would you mind listing the software that was installed on the computer?
For the video card, does your card have a port similar to this:
Then you need a DVI cable, which is an inexpensive cable you can pick up at Radio Shack.
SOURCE: "Userinit logon application has stopped working"
Hi Just to let you know the run box is accessable in Vista by pressing the Windows key and R at the same time. You can also get to it through Task Manager, new task.
Hope that helps
