48" only showing a blue screen
I have two haier LED LCD televisions with all the screens broken. they are 39'' and 32''. I would like to ask where I can get the screens to buy in order to fix them. Thank you.
SOURCE: Receiving blue screen with "no
If you don't have necessary tools and test instrument and
can't troubleshoot the unit yourself, I would advice you to look for a
professional to isolate the problem. Also, check if your unit is still under warranty/extended
warranty period, avail it because the manufacturer will fix it for free.
Opening the back cover will void the warranty. Hope I helped you. Have a nice day! Thanks for using Fixya.
This symptoms indicated of TV tuner malfunction but we have to isolate the signal from fault. First confirm if the cable wire is properly attached to the tuner of the tv. Confirm also to your local cable provider if the signal is good and not the issue here.
If the signal reception is not the problem and confirmed that it is working fine, the tv tuner was already faulty. This part is where the cable wire directly connected and need to replaced with new one to back the channel in normal operation again. Part no. is printed from its body itself.
