Casio g shock
Note how the buttons around the outside edge of the watch match up to the compass directions on the outer ring of the watch face. Use the butttons on the NW, NE, SE, and SW positions.
This is a complex watch. You can download a manual here http://www.casio.com/products/archive/Watches/PRO_TREK/SPF40-1V/
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
SOURCE: i have a casio g-shock G7700-1 i cant change the time
Here is the manual
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=3095
SOURCE: how do you change a casio g shock from military
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
SOURCE: casio g shock dw-9052 how to change from military
You can get instructions from the Casio web site which will tell you how to set your watch..
Go to the casio
web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read
the number of the back of your watch and enter it into the search box
