How do you replace the control panel
SOURCE: whirlpool quiet partner II has power but will not run
Please go to this site and locate your manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GU2400XTP&siteCd=WHRCOM
They have lots of information about your unit.
SOURCE: Where to buy the replacement parts
repairclinic.com is the best place
partstore.com is good
appliance411 is decent too.
SOURCE: Whirlpool dub500xx-3 Is there a replacement
Check out www.applianceart.com they have a ton of options including stainless steel. If your panel is not replaceable, they also have stainless film that can go over your existing panel. Several other options too, some are funny.
SOURCE: My wife said the dishwasher just stopped with
Most likely you are correct the thermal fuse located on the board is probley going to be you culprit if you have already replaced the control board and did not replace the thermal fuse on the control...
these control boards are notorious for failure ,and the thermal fuse in some cases will cathc any problems prior to taking the control out ,but sometimes will alway the control to fail or a relay on the board will burn up internally ... sounds like your on the right track and have some mechanically knowlede of the machine... wish you luck
