My 800xl will run, but will not get up to speed. When you first give it throttle it will take off fine, at first, then its as though some sensor holds it back. It begins idling rough if not shut off. Let it site for a minute and it will restart and do the same thing. Or it will let you idle back to short. But get into throttle and it bogs down. I'm thinking some sensor has identified a problem and holding it back to keep it from, I don't know "Burning up". Any One have any idea's. On tight bugget but still want to play. Thanks for Any Help
Have you got any water in the fuel tank ?? very basic ski 2cyl 2stroke ! i recomend stripping the carbs and clean and check the diaphams have not gone hard also ! dont try and run it to clear the problem because if one carb shuts off the fuel feed then you will melt a piston !! then boo hoo no more play time !
