Comfort-Aire BHD-501 Dehumidifier Logo
tom weber Posted on Apr 02, 2014
No power, no error code - Comfort-Aire BHD-501 Dehumidifier
dwlamborg
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jun 14, 2014
dwlamborg
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
9744
Points
35
No power, no error code equals a dead dehumidifier. Far too costly to repair. I recommend putting those repair bucks towards a replacement dehumidifier. Frigidaire units are highly rated.
What does an E2 code mean? How can I solve that error? I have a Honeywell Dehumidifier model TP70WKN that is about a year old. It have been working well until now that start showing "E2"at the display
Step 1: Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Wait at least 60 seconds.
  3. Reconnect the power cord to the rear of the printer.
  4. Turn ON the printer, if it does not automatically turn on.
  5. Wait until the printer is idle and silent before you proceed.
Step 2: Update the printer firmware
Click here to know different methods of updating printer firmware.
Step 3: Printing Documents
You can resolve the error by canceling the print job, and then changing the print settings in the printing software.
3answers
HISENSE MODEL DH7019KIG Dehumidifier. What does code E9 mean please?
Question edited for clarity and spelling of maker name.
Question moved from Computers and Internet category.
Faulty Sensor
https://www.google.com/search?q=hisense+model+dh7019kig+e9+error+code
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
1helpful
I have a Frigidaire LAD504TDL dehumidifier and code 'ES' shows on display. What does this code mean? Unit runs but not much water in tank.
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
The F2 code is on in the humidity window of my Frigidaire dehumidifier? Not in manual. What does this mean?
Good Morning friend, thank you for your inquiry!
I see that you are having trouble with your Frigidaire dehumidifier displaying an error code of "F2". Typically, an "F2" error code stands for a miscommunication error. This could be a possible problem with a sensor or control panel. I would suggest performing a reset and that can be completed by disconnecting the power from your dehumidifier for roughly ten minutes. If you are still under warranty I would recommend contacting your manufacturer to see if any additional assistance can be provided. Hopefully this is helpful. -Matt
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Top Comfort-Aire Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
