I have been using Print Artist for a number of years and I find they are a very excellent product. However I have a problem with my current edition of Print Artist version 24 Platinum Edition. I have been using it on Windows Vista for a couple of years and have recently upgraded to Windows 7. Since then my Print Artist now seems to stop working for no apparent reason. I have reloaded it a couple of times but it has just happened again. Do you have any advice please as I feel I am not using my pc to the fullest extent without Print Artist. Many thanks. Peter O'Sullivan.
SOURCE: Printing CreataCard Platinum 7 with Vista
if there are they will be on their website, but i'm going to say you've probably made that software useless and will have to buy a new program
SOURCE: every time I try to boot up print artist platinum
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
SOURCE: I have a Gold Edition Print Artist Version 22 and
Customer service is here http://www.novadevelopment.com/support/customer_service/index.html
SOURCE: With a Windows 7 operating
Hi Joni703:
I would recomend running your old Print Artist 8 in compatability mode, since you are dissatisfied with the new programs. to do so, install the program on your windows 7 system, if you have not tried already, and right-click on the corresponding desktop shortcut. When a menu comes up, left-click on properties. at the top of the properties window, click on the compatability tab. Next, click on the check box labeled "run this program in compatability mode for:" and pick the system you have used Sierra Print Artist Platinum on previously. It should function normally.
SOURCE: Is Print Artist Platinum Edition
Print Artist Platinum Edition version 22 is compatible with Win 7.(x86 X64)
You can check this @ Windows 7 Compatibility Center
Hope it helps.
