SOURCE: Pin settings for Acer Veriton 5600g motherboard
go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
http://www.acerpanam.com/synapse/data/7117/documents/vt5600.pdf
good luck
terry
SOURCE: emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
SOURCE: need manual for Matsonic MS9377C
I'll take a pix and email to you. email at [email protected]
SOURCE: I need the settings for the front panel connectors.
just visit the following link which has the manual to your motherboard. download and look for front panel settings in the pdf file.
hope this helps
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=1065&DwnldID=15210&strOSs=109&OSFullName=Windows*%20XP%20Professional%20x64%20Edition&lang=eng
