Creative Labs ZEN Vision:M Digital Media Player Logo
A
Anonymous Posted on Apr 02, 2014
Firmware problem having firmware problem
1helpful
Firmware for Koolertron honda accord Blue Tooth Radio
It sounds like you are looking for firmware updates for a Koolertron Bluetooth radio installed in your Honda Accord. Firmware updates can help improve the performance and stability of your radio.
To find firmware updates for your Koolertron Bluetooth radio, you can try the following:
  1. Visit the Koolertron website and search for your specific model of radio. They may have firmware updates available for download.
  2. Contact Koolertron customer support and ask if they have any firmware updates available for your radio. They may be able to provide you with a download link or instructions on how to update the firmware.
  3. Check the manual that came with your radio. It may have instructions on how to update the firmware.
I hope this helps! Let me know if you have any other questions.
2answers
I have a Ricoh 161 but after a firmware update erro (NIB) the machine tries to continue the update. How I cancel the firmware update or reset the firmware in the machine? ----------------- Eu tenho uma...
You can not stop a firmware update.
Did you turn the machine off while the firmware update? If you did that your NVram is broken
I think that the only chance you have is with a new NVram. Sorry but you will have to put a new NVram.
I have a netgear WNR1000 and my xbox live doesnt work
Using Xbox Live with NETGEAR Routers Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); NETGEAR has Xbox certified routers!
Note that the listed, certified firmware may no longer be available; later firmware is likely to work, but is not certified unless listed.
There is no information on what will be certified in the future. But if an existing model does not appear on the product dropdown on NETGEAR Home Page, then it will not be certified.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Firmware upgrade was interrupted & now I can't connect to it. I have reset it 3 times & still nothing
TRY
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
1helpful
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
1helpful
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
Wrong firmware installed in HP LJ 3050
I am very sorry to have to be the bear of bad news. Usually doing a failed firmware update (or wrong firmware version) you have to return to factory or have a local computer printer shop that deals in HP printers repair this firmware mixup. There is sometimes a firmware recovery mode that can help however You would have to contact HP and ask them how to get into firmware recovery mode.
Sorry hope this helps answer your quesiton.
Steven.
Chicken uploader
well you need to kno what firmware you have first, for instance i used a 5.03 chickhen which needs you ro either have 5.03 or below to run,
if you have a newer firmware then 5.03 then simply look up the chickhen for firmware on google, then locate the gen files for that firmware also,
so if you wanna play emulators like snes then use just chickhen, but im sure you want to do more so try to find the gen version for your firmware,
simply google example: Chickhen for firmware 5.50
simply put ur firmware instead of 5.50
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
