Uniden BC72XLT Handheld Scanner Logo
A
Anonymous Posted on Apr 02, 2014
Lo found when I start scanning the scanner says lo found and stops scanning
How to get windows to see the scanner every time.
Buy and install the 'Viewscan" scanner driver utility.
Then: Found that for windows to reliably see the scanner start windows, go to device manager, turn the scanner on and as it goes through its setup, right mouse click and select "scan for new devices" Windows 7 will now see the scanner right away.
2answers
How to remove/delete 'conduit.search.com'?
conduit.search.com is a adware.
I recommend that you install a good anti - Virus application and scan your computer.
For the time being you can use Malwarebytes. It works good for these Trojans. Please install it and then scan the computer. It would be better if you scan the computer in safe mode.
You can download Malwarebytes from:
http://downloads.malwarebytes.org/mbam-download.php
Additionally also scan the computer with Eset Online Scanner.
Eset Online Scanner
**Note** You will need to use Internet explorer for this scan - Vista and win 7 right click on IE shortcut and run as admin
Go Eset web page to run an online scanner from ESET.
  • Turn off the real time scanner of any existing antivirus program while performing the online scan
  • click on the Run ESET Online Scanner button
  • Tick the box next to YES, I accept the Terms of Use.
    • Click Start
  • When asked, allow the add/on to be installed
    • Click Start
  • Make sure that the option Remove found threats is unticked
  • Click on Advanced Settings, ensure the options
    • Scan for potentially unwanted applications, Scan for potentially unsafe applications, and Enable Anti-Stealth Technology are ticked.
  • Click Scan
  • wait for the virus definitions to be downloaded
  • Wait for the scan to finish
When the scan is complete
  • If no threats were found
    • put a checkmark in "Uninstall application on close"
    • close program
    • report to me that nothing was found
  • If threats were found
    • click on "list of threats found"
    • click on "export to text file" and save it as ESET SCAN and save to the desktop
    • Click on back
    • click on finish
    • close program
2helpful
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
3helpful
Is there a wia driver for Windows 7 for the Kodak i65 Scanner?
Well I too HAD this problem. Upgraded to Win7 64 bit and was unable to install the existing 32 bit drivers (of course) that operate in WinXP and Vista. Called Kodak and there wonderful answer was Buy a New Scanner.
Well this was just not an option. SO I searched and searched for alternatives, to creating a WinXP Virtual machine with VMPlayer or VirtualBox to remote controlling an older WinXP laptop connected to the scanner. None were solutions I felt I could live with.
Then I found VueScan at www.hamrick.com. A small chea scanning software that you can try before you buy. I read through everything on the site including the specific scanner notes for the Kodak I65, then downloaded the trial version.
Once installed you follow the instructions from the site to use VueScans own driver to run the Kodak scanner and lo and behold I got my ORIGINAL Kodak scanner menu to work on Win7 64bit. Then I used the VueScan software to scan a document and it worked like a charm. Albeit with the VueScan watermark.
Now I could have stopped there and called it a success, but I then, tried scanning with my Nitro PDF Pro software and was amazed to get a Perfect scan without the watermark.
Now NOTE, I did not buy the VueScan software at this time, as I don't need it's ability. I just used their driver and driver installation instructions from the website specifically for the Kodak I65. Most likely going to buy the basic version of the software anyway, as I think the guy deserves something for saving my EXPENSIVE I65 from becoming a paperweight.
An Elegant and Complete solution to Kodak's total support failure!
N
Jun 08, 2011 • Kodak i65
I want to use my old Benq s2w 4300u scan to web in my macbook pro. What to do?
SOLUCION:
1) Baje los drivers del scanner desde este sitio (ftp):
http://downloadnew.org/drivers/scanner-camera/benq-acer-4300u-scanner-driver-download-326832.html#dlink
2) Después de hacer el download y poner los drivers en una carpeta ya descompactados, pues debe dar click derecho sobre SETUP.EXE y en el tab COMPATIBILIDAD marque compatibilidad con WindowsXP - SP3, y también marque ejecutar como administrador. Esta instalación es la única que he encontrado OK.
3) La instalación habilita un nuevo programa denominado MIRASCAN.EXE, no lo ejecute pues le va a decir que no hay SCANNER conectado y demás. Observe que en el administrador de dispositivos le aparecerá el SCANNER como un periférico correctamente conectado, y esto es lo principal, pues indica que el sistema lo ha reconocido correctamente.
4) Para scannear cualquier imagen Ud. debe ejecutar la tarea "Fax y Scanner de Windows", que es nativa al Windows7, y se sorprenderá cuando vea que con la misma si que puede scannear cualquier cosa y guardarla como .JPG o con el formato que desee.
5) Gracias a todas las personas que pusieron el driver correcto en este sitio.
Buen Provecho
Lic. Héctor Fortún
Ciudad Habana
WHEN IT SCANS, IT DOESN'T GO TO THE DESKTOP, IT KEEP SCANNING. IN ORDER TO STOP IT, I HAVE TO TURN IT OFF ON THE PRINTER. IS THERE MORE FRIENDY PROGRAM ?
You have to select the location in which you want the scan to be saved. I don't have it on in front of me right now, but that's the same scanner/printer I use. I found that accessing the scanner from the utility program on the computer rather than the scan button on the 5610 is a thousand times better. If you start the scan from the scanner itself instead of the program on your printer, it will go to the default location specified by the manufacturer, likely 'my documents' or a numbered file.
Try this:
Click on the program to open it. Select the 'scan' feature. on the left hand side of the display window toward the bottom there is an option to switch the scan-to location. Click on 'Browse' and select the location you want. In your case, select 'desktop.'
Once you get used to it, it gets better. I haven't found a better program to run it.
2helpful
3answers
Most of the time my Nikon 5000 works well. Recently I encounter the following problem. After several normal scans the program stops after the physical scan. (can hear from the scanner movment.) Nothing...
Hi, I have the same problem. I am running on the same computer with the same software Nikon Scan without problems. Found out that the problem happens mostly when a crop is selected that just eliminates the scanning frame. Without crop mostly OK. However no reason why and no real solution
The frequencies on my scanner are not coming in
while the weather channel is coming in hi LO (lockout) so that if its programmed into a regular scanning memory it will skip. If that dont work look for a lock button or keyboard lock and press that then scan.
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Just bought this scanner used and having problems with Banks 3 and 4
while the scanner is scanning press buttons 3 and 4 and they should start scanning too, if they dont then go to the first channel in bank 3 manually and press LO to unlock it, then hit manual again to go to the next channel and press LO again to unlock it( all of the channels in the bank are probably either locked out or empty(nothing programmed into them)
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
