May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lcÂd-tvs/601553-samsung-service-mÂenu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
