The manual on how to do this can be found at www.babytrend.com.
To attach the Baby Trend Infant Car Seat, recline
the seat all the way back.
• Position the Infant Car Seat, facing toward the
rear of the jogger, so that the seat shell goes
into the Child Tray and latches into place.
(Fig. 13a) Check that the Infant Car Seat
is firmly locked onto the Child Tray before
using.
• Check that the front Child Tray is firmly
attached to the jogger's armrests. Make sure
that the car seat locks into the front Child Tray.
Then turn tabs on stroller frame to lock the
front of the car seat into the stroller. (Fig. 13b)
• To remove the Infant Car Seat, squeeze the
release handle located at the foot-end of the
seat and carefully lift upward on the seat.
Hopefully that helps!
Strollers with detachable infant car-seat carriers extremely practical. In the first couple of months, your baby can sit securely in the infant carrier while you go for a walk. As an added benefit, you can transfer your baby from the stroller to the car without having to disturb her, as you would with a pram. For older infants and even toddlers, you can use the stroller without the carrier. Most have seats where the back adjusts from nearly a full upright position to a full recline.
