The flashing on/off light in a Jacuzzi whirlpool bath may indicate an issue with the control system, and it's important to address the problem to ensure the proper functioning and safety of the whirlpool bath. Here are some general steps you can take to troubleshoot the issue: 1. Check the Power Supply:
- Ensure that the whirlpool bath is receiving power. Verify that the circuit breaker for the whirlpool bath is not tripped, and check for any loose or disconnected power cords. 2. Inspect the Control Panel:
- Examine the control panel for any visible issues, such as loose or damaged wires, connectors, or buttons. Ensure that there is no water or moisture present in the control panel area. 3. Reset the System:
- Some whirlpool baths have a reset function. Turn off the power to the unit, wait for a few minutes, and then turn it back on. This can sometimes reset the control system. 4. Refer to the User Manual:
- Check the user manual that came with your Jacuzzi whirlpool bath for specific information on troubleshooting and resetting the control system. The manual may provide insights into the meaning of the flashing light and how to address it. 5. Contact Jacuzzi Customer Support:
- If the issue persists and you cannot find a resolution through the manual, contact Jacuzzi customer support or the manufacturer for assistance. They may be able to provide guidance on how to troubleshoot and resolve the issue. 6. Professional Inspection:
- If you're not comfortable or able to identify and fix the issue, it's advisable to seek assistance from a qualified professional or a technician experienced in Jacuzzi whirlpool bath systems. They can perform a thorough inspection and diagnose and repair any electrical or control system problems.
It's essential to prioritize safety and follow proper procedures when dealing with electrical components and water. If you're uncertain or if the troubleshooting steps don't resolve the issue, it's best to seek professional assistance to avoid potential hazards.
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump. The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on. If the bath pump comes on then you know you have a bad air button. If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power. If the bath pump comes on then you know you need a new air switch in the motor. If the motor does not come on then you need a new bath pump.
Adjust your tower to let the bowl fill up more.....google your problem if you dont understand...depends on what kind of tower you have....should have teeth on the tower itself to make it fill more...try pulling up on the float...
There's no certain way for me to know which fill valve you have in there, but locate the float. This floats on the water level and turns off the water when the tank is full. There's probably a screw on the float arm that lets you adjust the float up and down, adjusting the full water level. You may be able to loosen a collar on the bottom of the fill assembly and slide the whole thing up and down (make sure you turn off the water valve when you do this because the whole thing can pull apart), or you may be able to simply turn the entire fill assembly which will raise and lower it if it's built that way. Make sure the new water level doesn't go above the level of the refill tube or the water will go down the tube and the valve will never turn off.
Check the ports under the rim and make sure they are not clogged. To do this you can use a nail or pin to clean them out.
Right under the rim of the bowl are these ports that allow the water to flow into bowl in a turning motion to aid in flushing and cleaning wall's of the bowl.
Inside the tank check the fill tube and make sure it is connected from the fill valve to the over flow tube. Also check the fill level in the tank and make sure water is up to the line on the fill tube about 5/8" from top of tube.
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
