Kenmore Elite 45986 Front Load Washer Logo
Posted on Jun 15, 2009
Kenmore elite flashes f1 code and stops
Kenmore elite stops running and flashes a f1 code what do i need to do
  • Anonymous Mar 17, 2014
    code f1 keeps appearing
  • Anonymous Mar 20, 2014
    kenmore elite
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Jun 15, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
5633
Points
74
If I remember correctly? It is stopping after the wash cycle and won't spin? If this is correct you need a new pump. I found out that front load washers have a filter that is behind that front cover and it needs to be cleaned every 6 months or more often if you have lots of strange items that show up in the wash like coins or toys or if you have lots of furry pets. Mine did that with out the code and I replaced the pump and check the drain every 6 months or so. I was told a good indicator that the drain filter is getting clogged is when your washer has an odor. Just a rule of thumb.
1helpful
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
1helpful
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
1helpful
My kenmore oasis elite flashes f1 and wont run it's cycle? Can't find my manual.
The F1 error code indicates either that the pressure signal is out of range or the pressure hose is blocked. This would mean that the control board is defective or the pressure hose is pinched or blocked somewhere between the control board & the outer tub. You can check the pressure hose by removing the rear panel & looking where the drain hose is coming out of the back of the cabinet.
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
2answers
repl/ main control board reason for error code F 1 ,,,nothing else
1helpful
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Alexander
vince
