SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
SOURCE: Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
SOURCE: Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
SOURCE: removing limescale from iron and steam chamber.
1/4 C. Apple Cider Vinegar : 1/4 C Water
Pour into the iron and let it steam through; have anything that you want to have a permanent crease -- like pleats in a skirt or the front seam of slacks? The vinegar/water mix will make it a strong pleat. When pleated skirts were the fashion in the 70's, I had a white gaberdine skirt and used clear vinegar to avoid any discoloration, and the pleat would not quit!
