Fblowing fuses on power up
The XR8600D is a switched moder power supply with switched mode amps in it...if it is blowing fuses it needs to go to a shop..if you bought it new it has a 5 year warranty, you need proof of purchase or have registered it with the factory...it will be repaired and shipped back no charge. We do this.
And why would equipment blow a fuse the minute you turn it on? Well, I would say because it's defective. Bad power supplies, burnt components, shorted diodes and/or transistors or dead IC's. It's repair shop time bud and make sure that shorted speaker wires or defective speakers didn't damage it, as reconnecting a freshly repaired unit to the same wires/speakers could damage the unit twice.
SOURCE: my husband purchased one of
View videos on YouTube regarding "mixer setup". Find the parts of setting up of "effects". Don't worry that you have a different mixer, the principles are all the same for analog mixers. Steps are this: Set the EFX send level for EACH of the input channels (knob above each channel gain) for the proportion you want for each channel. Check that the level you are sending does NOT cause the effect clip light to light very much. Set the effect you want, delay, echo, etc. with the selector knob. Advance the output sent to the power amp with the two knobs in the upper right of the panel. Adjust the "time" knob for the delay or effect depth you want. Then go over the same settings in the same order until you get the sound you want.
SOURCE: How do i hook a
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
