Question about Lexmark X656DE Multifunction Printer - 16M1797
On an X656de, how do you stop it automatically changing to another tray if the tray it is using runs out of paper?
We have letterhead in the multipurpose tray and when Tray 1 runs out of plain paper the machine automatically defaults to drawing the letterhead and this is wasteful because all of that used letterhead has to be dumped.
6ya staff
SOURCE:
Anonymous
  • 167 Answers
SOURCE: Selecting a default paper source for a specific program
That what you want is not TRAY 2 it is Manual feed!! That is need to select to be default or you can empty Tray1 and feed Tray2 and select feed automatic! This both solution will work you choose witch appropriate to you!!!
good luck
Posted on Jan 30, 2008
Anonymous
SOURCE: Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Posted on Sep 22, 2008
Anonymous
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
Posted on Mar 10, 2009
Anonymous
  • 3 Answers
SOURCE: Lexmark T642 - I have plain white paper in tray 1
You need to tell the printer that the two papers are different. I assume they are the same size so the printer thinks they are the same unless you have configured the Paper types to be different.
Set Tray 1 type as Plain and Tray 2 type as custom 1. hope this helps
Posted on Dec 09, 2009
dreid65
SOURCE: Won't use tray 2 when tray 1 is empty
Have you tried checking that tray 2 has the same paper type as tray 1. If your machine is network attached, you can access the embedded web server (where device settings can be adjusted) by entering the device IP address into a browser. Find the web address from the machine by going to menu (key icon), reports, then arrow over to network set up page. NSP is a 1 page report which will tell you the IP address. Go to a web browser and type in that IP address. Should take you to your device web page. From that page you can change the device settings (click on settings and then paper menu). Check to be sure that the same paper type is set for both tray 1 and tray 2 (and be sure that tray 2 is showing up on the list). I had to power the printer back on for it to recognize tray 2. Hope it helps
Posted on Mar 24, 2010
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
How do you stop the headed paper in the by pass tray being used when the plain paper in the main tray has run out? I have wasted so much headed paper by the machine switching without any warning.
the device is programmed at the factory as a default to switch. try two things,1st function, general, key operator, code 0000, then at number 1(paper size) select bypass and then change media to letterhead or something other than plain.
2nd, function, general, key operator, code 0000, then at number 4 ( special paper tray 1) designate the bypass as a special tray. this should "exclude" the tray from available tray. good luck
Apr 07, 2010 | Panasonic WORKiO DP-C262 Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
Is there away of getting around the paper orientation when I duplex.
This cant be right, if you print on one side, then it is the same as when it prints the first page of a duplex print.
Paper should be face down, head to front for both, make sure you are using duplex driver for your printer and duplex option is ticked. (4250DuplexTwotrayNetwork)\
make sure trays on machine are identified with correct papertype (tray 2 plain and tray 3 letterhead or vice versa)
printer I beleive has setting too enable duplex in print menu.
tray one in manual feeder on these.
When I set these up sometimes I install the print driver twice, ones set to use letterhead and the other plain, so customer can just choose which ever one at print time.
Usally it is set up that you go to driver and select tray or windows decides depending on what doc type is set on what you are printing.
So you need to check settings on printer paper handling and printer menu, you also need to check driver on pc, if on a network you may need to have admin rights to change driver config on server if your system requires it. But you need to check drive has coorect tray/paper type and options too
You also need to check doc type settings on individual document being printed
I have 1000's of customers, running HP (including 4250dtn and this has never been a issue raised.)
Ignore manual, stick letter head in tray 2/3 face down front and print single sided, then use same tray and do it duplex, it will do as the first one did then turn it over and print other side.
I think most customers don't duplex on letterhead, they use that as cover then duplex on plain, but I cant see it not working if you did, otherwise I would of come across it buy now, this machines format has been around for ages and they are great workhourse printers once noisy swing plate gear fault is fixed (common 4250 fault)
Nov 02, 2007 | HP LaserJet 4250dtn Printer
Printing using various trays
Yes
Set tray (3? ) or other non standard paper type trays to type setting of letterhead and set normal paper tray (2) paper type to plain .
You do this on printer keyboad find menu then find paper handling, tray xxx, paper type. xxxx...set or tick
Via operations panel you can also printout current settings too to see if you have done the change if you do one before and after
Then test,
There are other settings on your printer that can effect this and driver configuation and doc type setting on pc that can effect this also but try step above first and report back if still having issues. Is it run by a server? Do you abity to change driver settings on your pc?
Oct 19, 2007 | HP LaserJet 4350 Printer
Lexmark X656DE Multifunction Printer - 16M1797 Logo
54 people viewed this question
Top Lexmark Computers & Internet Experts
Duncan Mutch
Shawn DuRee
ray gallant
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
