I need to clean the food trap in the right rear corner of the inside of my dishwasher. The trap has lots of little square holes, and it's awkward to reach. Is there a way to pull it out to clean it?
Try a shop vac, it should suck it clean. I would suggest rincing the dishes before putting in the dishwasher but then what would you expect a Dehumidifier guy say!
not that big of a job ! it just needs a good cleaning out, start by unhooking power and then remove outer case , look inside at area that has lots of fins !! fine aluminum ones !! there should be a water tray just below the fins ! im betting this is well garb'd up with yuk!! take a 50/50 water bleach solution (gloves would be a good idea too) and work some f this around in the tray till it loosens up , remove with old towels or rags (throw em away) and find the drain hole in the tray that allows the water to drain into collection pan and poke down it with the end of a old pencil to clean it out as well (don't use metal) don't forget to clean your fan blades off too before reinstalling cover and leveling unit before reconnection power
well first ive never read in any manual that tells the homeowner to remove cover on any apliance , in fact the only cleaning ive ever read is clean the filter , this is right in front on side and slides right out and can be washed in sink with soap and water (do not scrub) but yes cleaning the condenser coils will require you to remove cover this is purposly made somewhat a challenge to discourage homeowners from hurting them selfs as there are live electrical parts and sharp edges inside , i sugest a qualified appliance repairman be contracted to have a look
units that leak some times are a total loss but not allways , sometimes its just not being used on level surface (water seeks level allways) , there are lots of ports inside that need to be kept clean for all the units water to drain out , look inside with a flashlight to see if any buildup is obvious that might be cleaned off ? if not a last effort is to remove cover to see 1st hand what cause is(remove power plug 1st) , rust /mold/dust are all common things to find inside that affect units operation
Take out bucket. Remove front cover two screws bottom left and right. Just inside lower left is a wiring harness with a clamp. Pry off and clean rust from clamp and tubing it attaches to. (if you put the bucket in and hold sensor between fingers the humidifier will start to work) Reattach clean sensor to clean copper tubing.
2. Remove the bucket from the holder. Look up inside the holder, just in front of the louvers and you may see a plastic pull tab type handle. This will be the handle to the filter frame. Pull it down and out of the unit. Since it sounds like it has never been cleaned, wash it in warm water and dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter in place, as it could cause damage to the unit
2. If the filter was not located in step 1, on the right side of the unit, just behind the louvers, there may be a pull open trap door. Flipping that door open, will give you access to the filter and it's removal. Clean it as described above.
The above are the only 2 places I know of, that the filter can be located in on a Delonghi Dehumidifier. Unless, your unit is over 10 years old. In any event, I hope this helped you.
Hazel, I assume you want to know how to find and remove the filter for cleaning.
The filter is located behind the front air intake louvers and depending on which model you have, the filter can be accessed one of two ways. Before you attempt to remove the filter turn the unit OFF and unplug it.
1. Remove the bucket from it's holder. Look up inside the bucket cavity, just inside the unit behind the louvers and you will see a tab type pull handle. This is the handle to the frame of the filter. Pull it down and out.
2. As you're facing the unit on the fight side just behind the louvers, there will appear to be a trap type door. Open this door and you will have access to pull the filter out.
You can clean the filter in one of two ways: Vacuum it or it it's really dirty, wash it in warm soapy (dish washing liquid), rinse and dry thoroughly. NEVER operate the dehumidifier without the filter in place. Doing so, can cause damage to the unit.
Be sure the unit is clean inside. It sounds like there is not enough air going over the coil. If you are comfortable with it, you may want to remove the covers and thoroughly clean the coils (may have fins clean them as well). It doesn't take a lot of air restriction to cause this problem.
Although unlikely it may have lost a little bit of its charge. Good Luck, Gilshultz
