The circuit board was shorted; melting some pathways. it's cheaper to replace then attempt a repair. i already replaced with wire soldered in its place. no go. something else sparked. the motor worked for 1-2 seconds. it's new (2-3 years). if it cost less then $100; it's worth it to me. i bought it off season $150 below retail.($100)worked great till i messed up. also no luck on internet finding anything on parts.
SOURCE: GE Profile Harmony dryer sounds like a jet plane about to take off
KathleenA
I too have a GE Profile Harmony (Gas) Dryer that had started vibrating and making a loud noise. I removed the screws that held the filter and grill to the inside of the door frame and placed a mirror inside so I could see down inside the fan. I found that a softner sheet had somehow gotten around the filter screen and had lodged in the blades of the fan and had collected a fairly large amount of fine lint. The combination of the dryer sheet and the lint had created an out of balance condition that caused the dryer to vibrate and make noise (the forward cabin door has been closed and we're ready for takeoff!) I used a bent coat hanger as a hook and using the mirror to aim the hanger, I hooked the dryer sheet and pulled it out through the hole for the filter.
I hope I'm not too late to help you if indeed this is your same problem.
Theron
SOURCE: GE Model #JBP76GS1WW Oven Control Knob
First contact GE directly, they will send you replacements for half that price and you can do the labor yourself. 1-877-959-8688
SOURCE: replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like http://www.partadvantage.com/store anywhere from 150-400$
SOURCE: GE Fridge #GSS25LGMBWW water and ice control panel not working
Your dispensor board , has lost communication to the main control board . You will need to replace the board , which is located behind the refrig , behind the 8 " X 10 " , small panel . The pt # is WR55X10942 . You do NOT need to replace the board on the dispensor . The board behind the refrig , is , easily replaceable .
SOURCE: GE Profile Wall Oven Circuit Board
the start buttom wont activate the settings what can i do to start.......
desperate
