XBOX console has a green light on, but shows nothing on TV
According to the microsoft website:
The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply can turn itself off when there is too much current, too much voltage, or too high a temperature. Under these conditions, the light on the power supply will turn from green to orange or to red. Or, the light will turn off. When the power supply light is green, the power supply is working correctly.
To help the power supply work correctly, always try to use the following best practices:
Basically, feel if it is overheated. if it is let it cool down. If not try a different wall socket. If that doesn't work you probably have a problem with your power brick or console. Try borrowing someone else's power cords.
