Sony Mobile Xperia M C1904 Smartphone - Wireless LAN - 3G - Bar - White SIM-free - Android 4.1 Jelly Bean - Qualcomm Snapdragon S4 Dual-core 2 Core 1 GHz - 4 GB - 4" LCD 480 x 854 - Touchscreen - Multi-touch Screen - 5 Megapixel Camera - Quad Band Logo
t
timlapointe Posted on Mar 30, 2014
How to hard reset xperia c1904
Need to hard reset and dont have pass code
Pavel Mityushkin
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 06, 2014
Pavel Mityushkin
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
522
Points
14
Http://www.youtube.com/watch?v=iayi5BfTlNE
1 Related Answer
kronoguy
Robbie Sleepy Whitworth
  • 248 Answers
  • Posted on Nov 23, 2012
SOURCE: xperia u hard reset
http://www.sonymobile.com/gb/tools/update-service/
click on Download update service
follow on screen instructions, to erase and factory reset phone.
I dropped my phone in the bath it was fine for one min till i turned the screen off and now it wont turn on it charges and i dont know how to reset it. how do we reset sony xperia xa?
hi there.
not sure if this is your phone as you did not give model number.
but try this.
First method:
  1. In order to switch off the phone hold down the Power button for a short while.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Then selec Factory Data Reset and tap Reset Phone.
  4. Choose Erase Everything if you are sure you want to clear all your data.
More items...
SONY Xperia XA F3113 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/sony/sony-xperia-xa-f3113/
or this one.
Restarting andresetting your device Sony Xperia XA support Canada English
or this.
Restarting resetting and repairing Sony Xperia XA support English
or this.
SONY Xperia XA F3113 How to Hard Reset my phone HardReset info
I dont hear the ring when there is an incoming call despite the settings on volume is correct-It only vibrates.The alarm,Music,Video games,other media are ok-what could be the reason?
Please do check the Phone Ringtone
If the ringtone file is missing this may happen
Try change another ringtone (This option may be available under volume settings)
2answers
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA T LT30p
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 • Cell Phones
Forgot passcode lt30p
2helpful
3answers
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  2. Turn on SONY XPERIA S smartphone
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  3. Turn off the SONY XPERIA S
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
2helpful
Xperia u hard reset
2helpful
2answers
Phone locked Need to reset Dont know how
Heres how to reset without access to the phone.
  1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
  2. Hold the Left and right buttons located beneath the display
  3. Press and release the Power button
  4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Good Luck, second time someones asked for this model tonight so i had answer on hand!
2helpful
I cant unlock my sony ericsson x10 pattern code, it is now saying too many pattern attempts! and i have tried my google account but it isnt working and i dont know if i have to have a specific one as i...
Try entering the password null. If it doesnt worked means try to do a hard reset .
Top Sony Cell Phones Experts
Aron
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
