Color, contrast adjustments do not help
I recently FIXED a Samsung HDTV model: LN46A550P3FXZA that had a weird colors on the screen problem: sometimes red spots pixels, pixelating green or white where black should be and it depended on the input used. It was the T-con board (not the motherboard despite the differences in the inputs). When I got a brand new T-con board (model #: V520H1-C06) from eBay for $32, and swapped out the old one, all my problems went away! I see these brand new T-con boards sell regularly on eBay so it must be a very common problem. I hope this helps someone else considering replacing this T-Con board.
What do you mean by distorted?
are colors wrong? or are colors washed out?
Dear User...
You can adjust the
brightness and contrast of your monitor to improve the readability of text and
to make digital pictures appear more like they'll look when printed.
To improve the results
when adjusting the brightness and contrast settings for your display, use
Display Color Calibration. (Display Color Calibration helps you adjust these
color settings and others.) For more information about calibrating your display
color in Windows,
see Calibrate your display.
The way you adjust
brightness and contrast varies and depends on your specific display.
ā¢
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast
controls on the front and use the standard symbols shown in the following
image.
ā¢
On-screen menu. You can change the brightness and contrast settings for some
displays by using an on-screen menu, and then setting the brightness and
contrast in the resulting menu. Many times, you can view the on-screen menu by
pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
