Building Materials Logo
Red Ruiz Posted on Mar 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to take down a pocket door I installed so I can sand it, but I am having problems. I see the half wheel at the top with saw teeth and no matter which direction I slide it the door will n
Model #: PDFC150-00-68
Glenn Mayer
Level 2:
Novelist:
  • Expert 91 Answers
  • Posted on May 13, 2014
Glenn Mayer
Expert
Level 2:
Novelist:
Answers
91
Questions
5
Helped
74523
Points
212
Take the trim completely off that surrounds the track on top, after that you can simply lift the door up and pull to you or push the door away from you to clear it from the track! Hope that works for you Sincerely Glenn
1 Related Answer
Anonymous
  • 2992 Answers
  • Posted on Dec 01, 2008
SOURCE: My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Homelite chainsaw how to install a chain
HOW 2 TRUE UP YOUR BAR SO THE SAW CAN CUT STRAIGHT and
HOW TO replace a chain.
This is for first timers--so dont laugh too hard,all you old timers out there!
and maybe some of you old timers
should read this too, as you might pick up a trick or two.
You might say ," I always wondered why it did that and how to fix it."
first ,you need the proper chain to install so look at your owners manual for the chain number. or use oregon.com cross reference
you will need the make & model # of you saw as well as the bar length and their web site will cross reference you to a oregon chain #.
to install chain: loosen two shiny 3/4 inch bolts on the bar side of the chain saw and look low on the right side of the bar when viewed from the back handle of the saw for the chain tensioning screw.
it is black and has a single slot for a screwdriver.
loosening this screw (but only after the two 3/4 inch BAR LOCK DOWN nuts have been loosened ) will move the bar backwards towards the engine clutch sprocket.
look at the chain mounted on the bar and note the front of the teeth on top of the bar pointed forwards. also note that on the bottom of the bar ,the chain teeth are pointed backwards toward the saw handle.
REMemBER THIS ,so you dont put on the chain backwards and wonder why a new chain wont cut.
take the 3/4 inch nuts off compleatly and hold the bar on so you can see how things should look. you can put 1 nut back on snug to hold the bar in position while you learn your way around.
someplace inside there is a plastic raised picture of a chain tooth to remind you which way the chain teeth go.
there is a sheet metal chain guard sheild on the 2 studs that the 3/4 in nuts came off from. the bottom of the sheet metal guard has a 2&1/2in slot in it and the wings on top & bottom point outwards on the outside shield and inwards on the inside sheild .
P.S. the slots on the bottom of the shield allow the chain tensioner nib to move forwards to tighten the chain and backwards to loosen the chain.
remove the hold on 3/4 nut and take 1 outside sheet metal shield off the studs.
look at the chain bar underneath the two studs that the 3/4 inch nuts came off from. You will see the tip of the chain adjuster tensioning screw fitted through a hole in the bar.
now loosen the chain tension adjustment screw which will move the bar backwards and make the chain loose.
when the chain gets loose enough , you can remove it from the bar. but ,I bet that the will come off or fall off first. dont worry,this normal.after you take the chain off,you have to take the bar off anyways.
wipe the oil & saw dust off the chain,so you can see out of your good eye, like one eyed pete always says, and look at the bar rails.
these are the two rails that the chain drive teeth, the ones that go around the clutch sprocket and the idler sprocket at the tip of the bar ,fit into.
THESE rails must each be the same length or the saw will try to cut circles to either the right or the left. also, the chain teeth must be equally sharp on both the right side facing teeth and on the left side facing teeth, or again, the saw will try to cut circles either to the right or left. The only reason the saw cant cut circles is because the bar is too wide to make the circle. anyways ,the saw is susposed to cut straight and not in circles.
If your saw it cutting right or left,when you get far enough into a curved wood slot , you will reach a point where the chain teeth can no longer touch the wood and cutting stops, even though the motor is still turning the chain.
so,first we need to insure that the bar rails are even with each other and HERE is one way to do it.
Buy some 60 grit emery cloth and put it on a flat table top.
I use the top of my table saw, but any flat table top will work if the table is stable.
Place the bar with the rails perpendicular to the 60 grit emery cloth. THat means --at right angles to,or at 90 degrees,or straight up & down and sand the metal bar until
the rails are even and all chain chatter marks have been sanded off. This is usually the fine finishing step of severly
worn and burnt bars and works well for lightly worn bars.
ANOTHER WAY for really messed up bars is to hold the bar straight up & down on top of the table, with either your hand or clamp it in a bench vise.
DO NOT SQUEEZE THE RAILS together or the drive links of the chain wont be able to fit in the slot and even if they do fit in,they may not run in the slot because the slot is too tight;and that might burn out your centrifical clutch shoes or your electric chain saw motor.
Use first a course double cut metal file to even the chain rails of the bar and then a fine double cut or single cut file to do finishing strokes and then sand with 60 grit emery cloth as above.
Take the file and run it across the 4 inch wide sides of the bar where the rails are worn over the edge so that only a right angle, square edge remains between the 4 inch wide sides of the
bar and the bar's chain running rails.
this will allow the bar to go easily up and down in a wood slot without getting caught and binding and requiring extra force to free up, only to get stuck again & again.
IF YOUR BAR is too messed up for even a file to cure.
use the 6 inch or 8 inch side of a grinding wheel, to true up
the rails. a lighter grit ,like 100 grit circular stone is better than a 60 grit stone ,because the stone is fast and takes off a lot of metal quick . you can use a 60 grit wheel if you have a light sure touch and can see well out of your good eye but an old artheritis riden , and almost blind out of my good eye
unelse im wearing 2.75 power reading glasses , which always slip off my nose when im grinding anyways, id rather use the 100 grit,because its slower, like i am.
YET ANOTHER WAY to true up your bar is to use a bench sander with 60 grit belt. It does a good job , but eventually
you will cut through and rip your belt and have to spend $10.00 to replace it. thats why I dont use it much anymore
after ruining 1 belt & replacing it. But its great for those problem rails and beats spending $30.00 plus tax and $12.95 shipping for a new bar.
SO. now that your bar is all trued up ,we can finally put on the new chain.
You should save you old chain and buy a chain sharpening file and clip on angle holder for the size of file recommended for your model chain. cost about $10.00 and you can get 10 to 15 resharpenings out of one chain
before you end put taking too much metal off the cutting teeth or stretch the chain out too far or break off too many teeth by hiting nails in the wood. (ive done it all) and speak from experience.
NOW, PUT THE BAR back on and make sure that the nub of the chain tensioning screw is in the hole in the bar. You can put 1 3/4 in shiny bar lock down nut on finger snug to things in place. next ,put the chain shield back on the studs and insure that the slot is down [on the bottom side] and that the tenisioner screw nub is still in the hole of the bar and that the shield wings are angled outwards. make sure that the tensioner is all the way towards the back saw handle so the bar is loose and install the chain on to the bar with the cutting teeth facing forward on top of the barand backwards on the bottom of the bar. all the drive teeth should be inside of the top bar rails and should be properly engaged on the clutch sprocket.
If need be ,check the clutch sprocket engagement of the chain's drive teeth by removing the outer shield to look see
and reassemble. place the plastic cover on the 2 bar lock down studs and finger tighten the two-3/4 inch lock down nuts . I usually finger tighten only one of the 3/4 inch lock down nuts in case something pops out from where it is susposed to be ,as it usually does.
NOW, take all but a little bit of tension off the 3/4 inch lock down nut so that they bar can move forward when the screw tensioner is tightened. AS you tighten the bar, the drive teeth will be pulled into the rail slots on the bottom of the bar.
You will need a look see to insure all the drive teeth are inside the rails. Tighten up the chain until it has about 1&1/2 inch slack in the center of the bar and tighten up finger tight
one or both of the bar lock down nuts. now test the chain for free running by turning the chain by hand.
BE VERY CAREFUL where your fingers pinch the chain between thumb and index finger because you dont want to pinch a cutting tooth. you also dont want to loose your grip and have your fingers slip into a cutting tooth.
If you start with the chain somewhat loose,you will feel how easy it is to turn the chain by hand. as you tighten the chain,
it will become harder and harder to turn until it locks solid into place.
WHEN THE CHAIN GETS HARD to turn,this is when you can loose your two finger grip and have your fingers slide into a cutting tooth. the chain is already too tight to run without burning up the clutch a little. loosen the chain until it runs freely but does not sag more than a 1&1/2 INCH TO 2 INCHES in the middle of the bar. There is a point where the chain will not run any more freely even if it is loosened more.
if you hit this point tighten up the chain some until you feel it begining to run harder. check the chain sag tension11/2 inch in the middle of the bar or 2 inch max if the chain seems to be running a little hard.
Its better to have the chain a bit loose that a bit tight but you dont want the chain so loose that it will come off the bar.
new chains stretch a lot a first and will have to be readjusted twice as much as an older chain that is done with most of its stretching.
tip
Frozen Car Window - How to free it up fast!
Hi. If you live in a place where winter means icing conditions, snow, sleet and such; you have probably experienced a frozen car window. When murphy's law kicks in the car window that usually freezes up first is on the driver's side. No fun when you want to go to a drive in window, or get the mail from a rural mailbox. What can be even worse is when the window is left open or partly open and freezes in that position... bbbrrrrrrrrrrr. <br /> <br /> For a quick fix of this problem without doing any damage to your car's window or the gasket that surrounds the glass on the outside of the door your will need a tool called a flush cut saw. If you have a Home Depot, Lowes, or most any hardware store near by you can purchas a flush cut saw for about $10.00. I like the Stanley Fat Max Flush Cut Saw which is also available at this link <a href="http://www.nextag.com/Fatmax-Flush-Cut-Saw-69621680/prices-html">http://www.nextag.com/Fatmax-Flush-Cut-Saw-69621680/prices-html</a><br /> <br /> A flush cut saw is unique in that there are teeth but the teeth are not bent, or set, to tear. Instead, the teeth are in a straight line with the rest of the blade. For this application, the teeth will cut but not tear the gasket.<br /> <br /> All you do is slide the saw between the glass and the gasket on the outside of the door. This will allow you to slice through the ice that is keeping your window from going up and/or down. It will also solve the frozen window problem without damaging the rubber gasket that is supposed to keep water from entering the interior of the car door.<br /> <br /> I keep one of these flush cut saws in my car during the Winter months. It doesn't take up much space but it sure comes in handy when a window freezes shut!
I'm in search of the *main body* for a vintage
You may have better luck finding another saw, but check into this site, and post your request on their bulletin board. I've had some good luck with them in the past.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2011 • Delta Saws
2answers
We have a Biro meat band saw that we have used for many years. It is now getting a black-ish or grayish substance on the meat (probably oil or grease). We have cleaned the wheels, the new blade, and (we...
Grease and oil flow down hill. Check the bottom wheel .If you see any sign of lubricant at center of wheel ,you may have to change a seal at that area. GOOD LUCK FRIEND.
Poulan pro model 4218 got caught in stump I was trying to cut down. Bar was bent. Went to box store where I bought the saw and bought "POWER CARE" 18A replacement bar and chain, brought it home and...
Try the easy solution first and post back if this does not solve the problem:
Insure your chain is on the teeth of centrifugal clutch sprocket correctly. It is easy to have it either on the inside of the sprocket or on the outside of the sprocket. If it is not on the sprocket teeth, it will not turn the chain.
1helpful
2answers
Craftsman 12" Bandsaw Blade Tracking Problems
Sounds like you have a saw with defective castings. Either cast out-of-true or deflect under pressure.
Jan 03, 2010 • Saws
My blade cut one 12mm round bar and broke tried anothertoo two blades they broke
Ok, I am gonna give you the secret. When they make band saw blades for metalwork,(assuming the blade is spec'd right for the application, the cutting teeth are not completely hardened for heavy use. Simply put, you have to break the blade in. This can be done in one of two ways. You can either reduce the speed of the band OR you can use half of the infeed force into the work piece. In other words, half speed or half feed for about 20-30 mins of cutting time and the teeth actually harden the rest of the way. This is not an accident. As a rep for a bandsaw company, this was the abolute #1 problem I got complaints about in the field. Of course, if you don't know the secret, you have to buy more blades from them. Convenient,huh? Try it my way and lemme know how it turns out.
Low presure and sand on bottom of pool
your filter is not set in to filter mode handle on top has a sprocket wheel under it, this is is not seated right try moving handle to different positions and see if this helps otherwise you have to remove handle to get to sprocket wheel and check if its damaged there are teeth on it see if any are broke hope it helps
1helpful
I do not know how to change the blade on a dewalt
I'm not familiar with that particular band saw but I have had a few different band saws and they all pretty much work the same.
Unplug the saw and remove the top and bottom wheel guards.
Look behind the top wheel and you should see a large bolt standing vertically it may have a knob on it or it may not, look on the bolt to see if it has stop nuts if so loosen them then turn this knob so as to lower the wheel enough so you can remove the old blade.
Clean the rubber tires on both wheels and install the band with the teeth facing down.
Now the tricky part, adjust the top wheel so that it is firmly against the band and turn the wheel slowly by hand (be sure the saw is unplugged) if the band "walks" one way or another, you will have to find the set screw or set screws that adjust the tilt of the wheel, adjust these until the band runs true on the wheel. When it does, tighten the wheel a litte more and turn again slowly by hand repeat this until the band runs true and it is very tight on the wheel, Put the guards back on before you turn on the power. You should be good to go.
5helpful
4answers
Chain saw cuts at an angle
I have seen this problem of a chain saw cutting at an angle brought up again and again on forums, and result in a variety of answers about sharpening the chain, or replacing the bar and/or chain. In a number of these requests for solutions, none of the advice has solved the problem. I have used chain saws for about 45 years now, and there is a condition that some chains develop with the pitch of the teeth or the guides...or both...that will cause them to cut to the left or right at an angle (usually left). While I have not figured out what causes this, I have solved the problem of correcting it. First, turn the nose of your bar and chain toward you on a bench, look down it like sighting a gun and take a look at each tooth and guide. If the saw is cutting left, the teeth or the guides (or both) on the left (while you are looking down the bar from its tip) will be pitched differently than the teeth and/or guides on the right. The pitch of those teeth or guides (those little ears that stick up about on-fourth inch in front of each tooth) will be: 1) too much in line with each other, or 2) the teeth or guides will be less pitched than the teeth or guides on the right side of the chain. Solution: take a large pair of lineman's pliers or similar pliers and pitch those teeth and guides to match those on the right side of the chain. Also, make sure the curved part of your chain teeth peek out around the outside edge of those guides. If the guides are directly in line with your teeth, they will hinder cutting by the teeth. You can do this with the chain on the saw if you don't have too much slack between the bar and the chain. Last, make sure that the chain guides are not as tall or taller than your teeth. If they are, you will need to file them down a little (with a flat file) until the teeth are slightly longer than the guides. Afterward, make sure the teeth on both sides are equally sharp, and go cut a straight cut! TennesseeBob
Top Stanley Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Stanley Building Material Expert? Answer questions, earn points and help others
