We recently just bought a home and in the basement we found a hotpoint electric range and it looks pretty old it has 2 ovens and the buttons to turn it on and off and to adjust the temp are on the top but it also has knobs and buttons for the ovens. so how do I find out how old it is
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
SOURCE: Oven does not heat
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
SOURCE: Hotpoint oven overheating
Yes this is repairable, the probe in oven called a thermostat,that wire that goes out the back small hole goes up to the oven temp. knob ie thermostat. part # .WB20K10004 you can find it at
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=824183&PPStack=1 about $60.00 good luck
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
