Frigidaire Gas & Electric Stove/Oven/Range /Cooktop Ultimate Griddle Logo
k
khan Posted on Mar 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was trying to on oven all of a sudden massage appear f10
F10 massage is blinking on display how can i remove f10 error
  • Official Brand Answer 2,267 Answers
  • Posted on Apr 02, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288895
Points
2557
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Why does the f1 code appear when cleaning my oven
Its an error must be the blower motor..one blower will blow air to cool tge chamber. try to open the unit & look inside
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
How to change the temperature display from Celcius to Farenheit
Hello Friend, that's a great question!
Please follow the steps below to change the temperature to Celsius to Fahrenheit on your Frigidaire range, FEF366CCA.
    ·Press BROIL. "-" appears in the display.
    ·Press and hold the UP arrow until "HI" appears in the display
    ·Press and hold BROIL until F or C appears in the display.
    ·Press the UP arrow or DOWN arrow to change F to C or C to F.
    ·Press any control pad to return to normal operating mode.
    Hope this helps! - Z
Electrical panel does not work
Hey John, this is JK. I understand that the display on your range is not working. You may have a faulty Electronic Oven Control (EOC). Please confirm there is power to the appliance. If there is no power verify that the power cord is properly attached to the unit, plugged into a dedicated outlet correctly, and that the circuit breaker/fuse is not tripped or blown. Also verify the power at the plug is correct. Is the time of day displayed when the clock button is pressed? Are you able to turn the clock OFF or ON? When the display is turned OFF the time of day will re-appear for a few seconds any time the pad is touched. To toggle the display ON or OFF, press and hold the CLOCK button until the control beeps once (about 15 seconds). If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
Kenmore self cleaning electric range issue with F10 error during self cleaning mode
You most likely have a failed oven sensor or the control / clock has failed. Self clean mode lets the oven get extremely hot and sometimes causes electronics to fail.
3helpful
2answers
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • 0helpful
    The oven was on at 350 degrees. All of a sudden the oven increased the temperature and displayed ER F2 error on the display. What was in the overn was instantly burnt.
    If you have a Kenmore or Dacor, Thermador, Amana Caloric, Westinghouse, Admirals, or if you have some retagged oven from this brands, F2 is temperature runaway, usually a bad temperature probe.
    On Admirals you may need to test the relay board.
    Try disconnecting power (trip circuit breaker or disconnect power cord).
    If the error is still there, test if the probe has continuity, then eventually replace it.
    On Whirlpool ovens F2 is a faulty keypad assembly.
    To get a technician to do the repair call the support number listed on the manual.
    Dec 15, 2009 • Cooktops
    Wont turn on, LED just blinking
    Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
    Gggenau offered a rep at 400-500 eur for this ! Shame on them !
    S:DOlberg
    Display blinks and then lights go out
    I have the same problem. i've been on the phone with Miele tech support. i'll let you know if i have any luck.
    1helpful
    Top Frigidaire Cooktops Experts
    Mike Cairns
    Mike Cairns
    RAJA NADEEM AKHTER
    RAJA NADEEM AKHTER
    Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
