Question about Toshiba 50 Inch Big Screen Flat Tv Theater View Rear Tube Projection Low Hours
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I'm trying to connect my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv. i have the hdmi to rca cable in red blue and green. do i need the red white and yellow or will this work...somehow? Help!
  • 3 Answers
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Posted on Mar 29, 2014
4 Suggested Answers
6ya staff
SOURCE:
John Riley
  • 441 Answers
SOURCE: How do you get 720P
use the green, blue, red for video and white, red for audio. This will deliver the best resolution fron the cable box, you will also want to adjust the setting in the cable box to activate the 720p output, you should find this in the video setting menu of the cable box
Posted on Jul 11, 2009
Anonymous
SOURCE: cannot get sound from blu ray via toshiba tv
I NEED THE RESET CODE FOR OLEVIA MD 537-B11
Posted on Dec 01, 2009
mndy67
mndy67
SOURCE: I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
not helping I am having the same issue
Posted on Dec 09, 2012
How does one stream netflix via Blu Ray wired to ISP through a tv?
First you have to hook up network cable to Blue Ray player and to router
Next update software in Blue Ray player by going thru your menu in blue ray player to settings
If you have your blue ray player with Netflix app then all
you do is click on app and log in.
And make sure HDMI cable is plugged into TV.
And that should work for you. Any problems write me back.
May 04, 2014 | Samsung BD-E5400 - Blu-ray disc player
How can I connect a samsung bdf5900 to my hitachi rear projection tv
Your TV is probably older and has Component, Composite and DVI connectors. HDMI is a newer connector that integrates sound. If your RPTV does not have HDMI but DOES have DVI, you can get an HDMI to DVI adapter on eBay or a computer store pretty cheap. You will need another way to get the sound from the Blu-Ray player, either external speakers connected to the player, or stereo RCA cables from the player to the TV (there will be a set of RCA audio plugs with the TV's DVI port).
Apr 30, 2014 | Samsung BD-F5900 Smart 3D Blu-ray Disc...
2005 mitsubishi tv
I'm assuming that your new blu-ray player only has an HDMI port and your TV does not. In that case, does your tv have a component cable output? This should be five plug-in ports (red, white, red, green, blue). Amazon sells an HDMI to component adapter that you can buy here: http://www.amazon.com/eForCity-538581-HDMI-Cable-5-Feet/dp/B005QWH4QA/ref=sr_1_1?ie=UTF8&qid=1382102257&sr=8-1&keywords=hdmi+to+component+cable
Oct 17, 2013 | Samsung Televison & Video
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
HOW TO HOOK UP HDTV CONVERTER TO PLAY VIDEO ON TV
Need more specifics. What TV do you have? If you just want to hook up the blueray, you can use an HDMI cable from DVD to TV, or red-blue-green component video cables, or red-white-yellow cables.
Feb 25, 2011 | Samsung BD-P1500 Blu-Ray Player
My blue ray sound will not come on but the sound works of tv programs
If you are using an HDMI cable make sure that your sound is not set to SAP initially. I usually test this by setting the TV to stereo to begin with and troubleshooting from there. The other option is to use the audio out cables provided with your player and plugging those into the red and white RCA jacks closest to the HDMI port.
Oct 29, 2010 | Samsung BD-UP5000 Blu-ray and HD-DVD...
HDMI - no output Samsung P1600 BD
the hdmi output generally needs activating through the menu system. im assuming you havent already done this.
connect it with whatever cable works and navigate through to the menu system to select the hdmi output.
failing that it might be the hdmi cable is an older cable not capable of supporting ver1.3
Feb 07, 2010 | Samsung BD-P1600 Blu-ray Disc Player
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Toshiba 50 Inch Big Screen Flat Tv Theater View Rear Tube Projection Low Hours Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
