I have an LG WFT653A washing machine and it won't fill with cold water so have to use a hot wash only but then it won't fill at all for the rinse as it is programed to only use cold always for the rinse normally. Anyway, a friend opened it up and swapped the solanoids (?) over but was still getting the same problem so they both must work but not in the cold side. Anyway, could it be something wrong with the cold inlet valve (if there is such a thing) that could be replaced by a whole new valve/solanoid system or is there another computer bit somewhere inside that it could be?? I don't want to buy a replacement valve/solanoid system thing if it doesn't fix the problem.
Thanks for your help. I am just a housewife winging it to save some dollars.
Cheers
Fiona
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
