You need to login to the routers web interface and the settings will be in the advance WiFi section, probably a tick box.
A typical web interface can be found at the following address in your browser http://192.168.1.1/
Username usually admin and password could be password or blank or 1234 or admin. Check with manual.
You will have to go into the router and turn the wireless off. You will
need your ip address of the router and the default userid and password
to get into the router. The user manual will give you all that.
Get online
and got to www.google.com In the google search box type: "Aztech
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals.
I was having the same router Aztech HW550 3G, exactly the same problem. Bought from Etisalat, UAE, completion of 12months the transmission signals were not happening. Till now I could find anything out in order to getting it working...
The solution I used was. I had a second router/ap that was wireless.
I then associated the #2 router/ap to the WPA main router,
And ran the Camera on wired mode thru the 2nd Router.
When you use an ext renal wireless AP that camera.
You get much better range. I had a che-po router.
And the range was 3x what it was using the cameras antenna.
To setup your router first check.. Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online, to setup connection.. Step 1: Connect the Broadband modem to the router’s WAN or Internet port. Step 2: Connect the computer to any available numbered port (1, 2, 3 or 4). NOTE: In this example, we’ll connect the computer to port number 3. Step 3: Make sure the power adapter is plugged to an available power outlet.
Step 4: check if you are able to go online wired..
if not your router has to be configured first, to config your router i need some more information your internet service providers (isp)name , and how many computers do u have totally..
