Makes Buzzing noise and burned smell, will not cook food.
SOURCE: burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
After the way GE behaved by doing business with Iran, wouldn't buy a thing from them. look for the equivalent product from another source. Jeffrey Immelt's citizenship should be revoked and he should be sent off to live on a deserted island
SOURCE: GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
SOURCE: I have a JVM1630WB GE Spacemaker microvwave oven.
It's almost certainly a shorted high voltage rectifier diode or a failed magnetron.
We have
the service / repair manual for this model and have uploaded
it to our
site here for free download to help you.
It will
give you safety info, step by step help in disassembly, troubleshooting
tips, and part numbers.
Here are some handy links you
or someone you know can use for test help:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
You can also find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
If
it's within the magnetron portion of the warranty (for this model it's 10 years from the date on the tag inside the unit)
but out of the original full warranty (1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
G.E. they will
send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the
magnetron warranty, you can find helpful
exploded view diagrams and order parts by entering your full model
number here.
Accessing some
components
(especially the oven cavity thermostat) for testing and possible
replacement will require you to remove the oven from the wall and take
off the outer cover.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can
download GE
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My3yr old GE profile microwave doesn't warm up
from what you are discribing , I would be looking at the high voltage transformer
