Mitel 5340 IP Phone Logo
A
Anonymous Posted on Mar 26, 2014
Transfer button has disappeared from screen
My transfer/conference button has disappeared from my main screen and i am unable to transfer calls to other associates
Doesnt ring when call transfered
When the Polycom is on-hook (not in a call), use the volume rocker to change the volume of the ringer.
Conference call
Panasonic KXDT321 Phone Conference Call
Call party 1 and speak
Press transfer
Call party 2 (press 9 for outside line if needed)
Party 2 answers
Press transfer then 3 speak to all three people
Repeat if required
1helpful
How do we arrange a conference call?
While on a call, press conference or transfer button(will put first call on temporary hold). Make call to next party, talk to party, press conference button to join all callers. Same procedure to add more parties up to 8 total.
Also, if you use transfer button to start conference call you can use transfer button to join all parties.
If you use conference button to start conference call use conference button to join all parties.
Can I transfer the incoming calls to a different number
The best way is to use the Flash button. You will have to have Call Transfer on each phone line you have with your phone company to do this.
So when you have a caller tell them you will transfer them, press the Flash button and you should hear a new dial tone. Dial the number you are transferring to then hang up or press the Flash button again to conference the three of you.
This is better than conferencing two calls together because as soon as you hang up your line is open again. If you conference two calls two lines will be tied up for one call.
2helpful
How do I identify extensions, transfer calls, conference call, change time.
To identify the extensions: if its a display set, press feature 00 and the screen will show the extension number. press feature 00 to exit programming.
If its a non-display set access the intercom and call a display set.The extension number will be displayed on the screen that is recieving the call.
To transfer a call: while your on the call to be transfered, press the transfer button and then the extension number of the person you wish to transfer the call toand hang up.
For a conference call:while on the line with the first caller,press the conf key (the caller will be placed on hold) place a call to your second party when they answer press the conf key again. all 3 parties will be bridged(you + the 2 lines) to get rid of one of the callers press thier line and feature 6 (conference drop)
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
2helpful
Conference call in Samsung SCH-S259 Model
first you calling any friend number then press OK on option button on the screen then click hold option AND then call second number of your friend and call him then goto option button of your screen and se option conference and click OK.
Call conferencing
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Unable to use conference button
33helpful
How do I make a conference call with the NEC Dterm 80? Thank you.
To establish a 3 way conversation.
  • Pick up handset and dial first number required
  • While on the call, press Transfer (TRF) button
  • Caller will be placed on hold
  • Dial extension number or external number
  • When called answered by third party, press CNF to establish a 3 way conversation.
Note: Any party may exit conference by hanging up
2helpful
2answers
Conference Calls/Transfer
Top Mitel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
