First of all, I am surprised that so many people has the same problem, which is very likely related to the power adaptor failure. I am glad that I saw this thread. Following the suggestions, I checked a local RadioShack store. Unfortunately, they do not have any of similar specs. Then I went to Fry's and got one adjustable power adaptor with interchangeable tips and 2500mA rating. Unlike typical adjustable adaptors with 4.5V and 6V, this one has 4.2V, 5V and 6V, and the 5V works! Even though it is a bit more expensive ($18.99+tax) than the one from the web ($9.99+shipping), it is the quickest solution for me. I am happy that I did not spend $79 for a new gateway.
SOURCE: modem power adaptor
On the bottom of the Modem, it usually lists the type of voltage/current ratio, for example, My modem is a 12VDC in, output is .75A Through the modem. Each modem has its own power requirements. Therefore if they dont match, you have the chance of either underpower (which means no use) or overpowering (and killing your modem permanently)
Best suggestion si the same as above by cnavarro, Buy the Right power supply for it, dont just try anything. get the matching one. Otherwise it will be Incident A or Incident B. Neither would work well, and you would end up buying a new modem all together.
SOURCE: Solid red power light
pls check the power supply this happens when the router's supply is faulty or the power outlet in WALL ,
otherwise try this see for RESET button on the back of Router press it for 30 SEC when ur router is ON and it will resolve for sure let me know if it doesnt solve i can help more
RATE ME WELL !
Regards
Zohail
SOURCE: Solid red LED for power, Solid green LED for wireless
You can try upgrade the firmware of the device first and then reset to factory default.
SOURCE: I have a 2 Wire Switching adaptor that went bad.
SOURCE: 2wire 2701HG-B got red light on power & green light on wireless
I had the same problem. I replaced it with my psp adapter instead now it works fine.
