Question about Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap...
Cannot find instruction to replace the ceramic cartridge and the pull out hose
I need to replace the two items above but cannot find a how to guide on these two items
Where can I get a replacement water filter for a kenmore 56722 side by side refrigerator? and what kind of water filter do I need...the original pur2 cartridge had 2 prongs on top not made anymore
for items not made any more
try this for a fix
connect across the existing filter head to eliminate the need for the filter at that point
now at a convenient point in the supply hose outside of the fridge , connect a common filter assembly and use a ceramic filter cartridge available from any filter supply shop
ceramic removes all taste and bugs and are cleanable by simply scraping the material off the ceramic
Aug 28, 2018 | Kenmore Refrigerators
Pope hose reel jams whilst extracting and on return,also very hard to pull out hose
The spring unit either needs replacing or lubricating.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 07, 2017 | Vacuums
HOW TO RESET THE DRUM WARNING LIGHT ON MY XEROX XC1020
Reset the Drum Cartridge NOTE: This solution should only be used if you have already replaced your Drum Cartridge and the Drum Light is still on. If you have not replaced your Drum Cartridge, refer to Related Items at the bottom of this page.
If the Drum Cartridge has already been replaced and the Drum Cartridge Light still remains lit, the Drum Cartridge needs to be reset. To view an animated guide of the Drum Cartridge Reset procedure, refer to Related Items at the bottom of this page, or follow the steps below.
  1. Turn the power off.
  2. Press the Release Button to open the top half of the copier.
  3. Remove the Toner Cartridge by pressing the green Release Button and pulling the Toner Cartridge straight out.
  4. Set the Toner Cartridge off to the side, out of the way.
  5. CAUTION: Be careful not to touch the red shiny surface of the Drum.
  6. Remove the Drum Cartridge.
  7. Face the end of the Drum Cartridge that goes into the copiers. You will see a series of gears.
  8. Hold the Drum Cartridge so that the large black gear at the end of the Drum is to your left. There will be an off-white gear above and to the right of the black gear. Below that is a set of three chocolate-colored gears across the middle. Directly below the middle chocolate-colored gear is an ivory white gear. To the immediate right of the white gear is a small black gear. This small black gear will be the gear to focus on.
  9. At the top of this gear is a Retainer Clip holding it in place, then the gear itself. At the very bottom or base of this gear is a flat black Reset Flag. Some describe this Reset Flag as looking like a flag or the blade of a hockey stick. The Reset Flag may be partially obscured by the ivory white gear.
  10. With your fingernail or a pen, rotate the Reset Flag counter clockwise so that it is next to the third or far right chocolate gear.
  11. Reinstall the Drum Cartridge.
  12. Reinstall the Toner Cartridge.
  13. Close the top half of the copier.
  14. Turn the power on.
  15. The Drum Cartridge Light should now be gone and there should be a '1' in the LED Display. If the Drum Cartridge Light is still lit, repeat all above steps.
Dec 08, 2016 | Xerox Office Equipment & Supplies
I bought both a new color and black ink Cartridge. 210xL is the kind and the printer is a Pixma Mp250 and I don't know where they go into the printer
Did an instruction manual or (1 sheet, quick instruction guide) come with your computer.
If so, you will be able to use the Manual or guide to show you how the printers cartridges are inserted.
IF Not THEN
You will have to contact Canon via their website Contact Form as they do not have the Printer listed in either the Australian or US website Printer List (which means it is a discontinued item). They should still be able to email you the manual however.
To get to the Australian Canon website Contact form, use the link below:
http://www.canon.com.au/en-AU/Support-Services/Online-Support
I hope this helps. Please rate. Regards,
Feb 13, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Where is the cartridge located?
take your hand above the paper tray and pull up on the printer.
Nov 15, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
My printer wont print it keeps saying press enter to alein cartridge
I just noticed in the link to your forum item that additional text appears that does not appear in the item itself. It looks like you are getting a message telling you to press Enter to align your print carriage. This is a common step after you replace an ink cartridge. According to HP.com, here's what you are supposed to do:
"A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete".
The link to those instructions is as follows:
Replace the Print Cartridge
Just follow the instructions I posted above in italics and you should be good to go. Good luck.
Oct 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon mp460 instructions missed
There should be a user guide on the disc that came with the machine. There is also a PDF on this site for it.
On the cartridge replacement lift the top and wait till the cartridges come to the rest position, there should be a guide there, but if not pull them down and fit new ones - they should push up into place. Close the lid, the machine will then reset if you have done it right.
PS make certain you remove the orange film from the new carts!
Jan 19, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap... Logo
44 people viewed this question
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
