HP Officejet Pro L7650 Printer Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computers not sensing scanner via LAN
I have a 2005 HP Pavilion Notebook running on XP & my wife has a new HPG60-243CL Notebook. We formerly printed & scanned with our HPOfficejet Pro L7650 through a USB cable and everything worked fine. Then we installed a new Lynksys WRT54G2 VI router and put it all onto a local area network so that we could print and scan without swapping the USB cable. Printing via ethernet cable and router now works fine for both of us, but our computers sense no connection to the scanner and vice-versa.
Please help us scan using our new router. Thanks!
Anonymous
Level 2:
Scholar:
  • Expert 88 Answers
  • Posted on Jun 15, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
88
Questions
0
Helped
62942
Points
227
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Laptop won.t start windows keeps saying that it is lookng for errors windows 8 hp
redux, 1 (old post mine)
not told how w8 got on XP PC.?
no clue there and does not belong on here.
2005 PC CAME NEW WITH XP NOT W8
Intel Pentium M or Intel Celeron M, NO!
_Intel 855GME/ICH4-M Chipset (zero support on 855 !!!
Intel ICH4-M South Bridge: zero support now. Intel ended it.
w8 UP do no like OLD PC.
the HDD this old is bad and will corrupt any OS you place there.
there is no intel support. so MS can undo that fact.
buy used 2010 and PC and RUN w10
w8 installed on a good PC can be upgraded to w10 for free.
Hp pavilion ethernet port is not appearing in devices
You didn't supply the HP's Model? Did it come with Win 7? Was it upgraded? If you go to the HP drivers and support website, using your model, download the Correct driver for your OS and Device, install, the driver software it will locate the device via the Hardware ID, and apply the driver. That's if the device is funtional. It may be a bad component? I don't know how old the machine is, components fail. The driver is a likely place to start.
2answers
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
My HP Pavilion laptop no longer connects to the internet via wireless.
When wired go to Lan Settings which is under Internet Explorer>Tools>Internet Options.>Connections>Lan Settings. Make sure no boxes are checked after clicking Lan Settings.
2answers
2answers
I need a lan driver for hp pavilion dv6500, the driver from hp website is not working
hmm run a Everest Analise software into your computer and see exactly what kinda device ( lan card ) you have ...cause it is possible that it was changed and this cause the driver malfunction ..
and please specify what kinda operating system you use...( if you changed the lan card yourself and know what model it is ...place it here ...
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-59636-1&lc=en&dlc=en&cc=pl&lang=en&os=2093&product=3380544
anyway ..if its the original ..this is the driver for all kinda Vista operating system
http://depositfiles.com/en/files/5848028
for xp try this one ...
My Hp pavilion tx2000 cant play audio files,cant connect to net
Hi James
First, Sound drivers:
HP Pavilion tx2000 CTO Notebook Realtek High-Definition Audio Driver 6.0.1.5494 A from HP notebook
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38206.exe
and video drivers..
HP Pavilion tx2000z CTO Notebook NVIDIA GeForce Go 6150 Video Driver 7.15.11.5682 A
http://notebook.free-driver-download.com/url.php?id=TlRJeE5Eaz0&link=0
Now network:
HP Pavilion tx2000 CTO Notebook NVIDIA nForce Chipset/Network Driver 5.53 A
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38205.exe
and wireless!
This is an older WIFI driver that only works in XP, and in certain HP Pavilions, but try it.
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36684.exe
and this is the Vista one that is correct for your laptop, it probably doesn't work in XP but if all else fails, you could try it. (You should really run Vista on it, I reckon)-----------------
HP Pavilion tx2000 CTO Notebook Broadcom Wireless LAN Driver 7.0 Windows Vista
http://notebook.free-driver-download.com/url.php?id=TlRJeE5EWT0&link=0
All support you need is here at HP Tech Support:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3650975
Good Luck
Merry Christmas
Chris (ziraffa)
k24674
Grand Canyon Tech
Grand Canyon Tech
