pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
my air-con remote control was out-of-order. How can I buy one in Hong Kong for replacement. My air-con model is SHARP CRMC A562... Thanks to acknowlege to my e-mail [email protected]
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
