I have an older sansa m200 series MP3 Player, and am trying to remember how to listen to a recording that i have made. I know how to record, but can't figure out how to listen to the recording (or play it back)?
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
SOURCE: SanDisk Sansa m200 series and my macbook pro
It is complicate,
it works on Mac OS only if you downgrade firmware for sandisk.
Here is how to do it.
If system crashes while you install the firmware you will damage the sansa, Mac OX is solid , but be careful with the USB cable.
Here is the procedure: How to use your SanDisk Sansa e200 Series .mp3 player with OS X ...
Here you can also download software
SOURCE: Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
SOURCE: my sansa mp3 player won't charge or connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: my mp3 player is stuck at the voice record screen
Reset it first by holding in the power button for 10-15 seconds. If that fails:
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
-Tha Mp3 Doctor
SOURCE: how do i delete recordings on a sanDisk Sansa m240
Manual for the m200 series, see:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
All about voice recordings in chapter 4, starting from page 22 of the manual.
On page 25 is the information how to delete recordings on the m240.
