Insignia - Flex 8 inch Tablet with 8GB Memory Logo
D
Dana Johnson Posted on Mar 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't get apps to remain on sdcard after firmware update
I updated the firmware to version 42.2 and afterwards the apps would not remain on the sdcard
Philippe Dekyvere
Level 2:
  • Expert 30 Answers
  • Posted on Sep 21, 2016
Philippe Dekyvere
Expert
Level 2:
Answers
30
Questions
0
Helped
50129
Points
105
They probably are
still on the SD card, but the apps directory index was overwritten in the main memory. Also, the app data is usually stored in main memory, so you would still loose your data settings part.
Read card on a computer and see if you find .apk files on the sd card. they may be hidden files. but you can not recover the data settings part unfortunately.
preventative backup is always the best. If they are google apps, make sure you backup to google in your google account settings
use your carrier backup to cloud for phones.
How to update tablet firmware
If there is a new version available, follow these steps :
Tap "check update" in "Settings"
Then go to "about" and go to "system update" to check if the firmware is latest.
Steps to update :
1) Go to "Need Help?" page of ASUS official website http://www.asus.com/support to download ZIP file of firmware.
2) click the ZIP file after downloading is completed
3) Connect your tablet with PC via micro USB cable, and copy the ZIP file to the root dictionary of internal storage of tablet
4) Detach micro USB cable from the tablet to make the notification for firmware update popped up on status bar
5) Tap "System Update File Detected.." and follow steps to update firmware
Now your firmware is updated.
How do I updat my ipad
There are multiple ways to update iPad. The easiest way is to do that in the Settings app. Follow below steps to reach the aim.
1. If a pop-up panel tells you that iTouch latest version is available, you can then tap on the button of "Install Now" to begin to update to apple iOS latest version.
2. You can also manually check out if the apple iOS latest version is available now. Now you can follow the steps shown below to have a try.
a) Connect your iPod to good Wi-Fi connection and make sure your iPod storage is enough and the battery is able to support the iPod update.
b) Click on "Settings > General > Software Update" successively.
c) When your iPod has detected an apple iPod latest version, you can click on the button of "Install Now". If a dialog requires you to delete some apps temporarily because the new version needs more storage, you can click on "Continue" to uninstall the apps. If you click on "Cancel" button, your apps will not be uninstalled.
d) After that, iPod will begin downloading and installing the apple iOS latest version in no time. Wait until the update is finished.
The process to update to iTouch latest version is not hard at all. Actually, before the update, you can manage your iPod files to make some room for the new version or to make the process much smoother. The next two parts will instruct you how to manage files via iTunes or iTransfer in detail.
For more methods, check: How to Update iPod to the Latest iOS Version
1helpful
2answers
How to install kindle 6 HD 4th generation software update
Hello Jeanette G Allen, If you want to perform your Amazon Kindle Update manually then you can follow the below-given link. While performing the update if you find any kind of issue then you are free to take kindle support from experts.
How to start an app that not loading at all
You should make sure that your iPad is running the latest firmware version. Also, make sure that your apps, especially the one you are having trouble with, is fully updated. These updates cover problems the software is having.
1. To check if your iPad firmware is up to date:
Go to "settings", then to "general" then to "software update".
2. To check on you apps update status, go to the "app store" icon,
then on the bottom, all the way to the right, there's an "updates" icon. The apps that have available updates are listed here. Make sure to update each out of date app.
Hope this fixes your problem!
When i open google a load of apps apear i wish to remove them all
You can not delete all apps, the ones that are installed with the firmware will stay, you van choose another firmware version, but this depends on your hardware version, check google on fireware update on your system, regards peter
Trying to download Safari 5.0 on my iPad and keep going in circles...
Hi!
Safari in iOS devices (iPhone,iPod,iPad) is system app, and is always updated with update of firmware (iOS), you can't update safari itself, without updating whole firmware.
I can not get my literati to join with my network
It needs the latest firmware 1.9 or 2.0 for the wireless to work correctly. The solution is to get the usb to work first. Plug and unplug the usb, try powering on with usb plugged in until you get the pc to recognize the drive in the literati. Once you get to this point you have it made. Browse the drive and find the "Desktop Installers" folder run the windows install - the pc will then go out to the internet and get the desktop software version that can update the literati. Once the desktop software finishes installing it will tell you that the literati must be updated. Let it do it. Power off literati or reset it. When it comes up again the desktop software will say there is another update. This one is a big one. After it finishes Power off or reset literati again and it will load the newest firmware and the device works much better afterward. Also, you might want to keep it plugged in to power while you do this - Don't want it to lose power during firmware update.
5helpful
2answers
How do yo update the flas softwer
As posted to another person, download this .apk file and install it on your A70 (It must be running 2.2 froyo firmware to work, if running 2.1 you need different .apk).
It'll give you Google Market, where you can download Adobe Flash Player that updates itself... i've had 2 updates from flash since Dec 25th upon getting this.
Link: With Archos 70 Internet Tablet, you need to download a specific version of Adobe Flash Player from Google Market since it runs Android OS. And A70 doesn't come with GMarket, rather Appslib, which doesn't quite cut it.
Luckily someone has made a neat little .apk file thath as Google Market, which lets you download GMarket and download/install all its apps/games/etc on your A70.
Just download the following .apk file and install it on your A70, afterwards download Adobe Flash Player from Google Market. However, this hack ONLY works on 2.2 froyo android OS, so make sure your A70 firmware is up to date.
I'd also recommend installing Dolphin Browser HD as it seems to provide a more refined flash browsing experience coupled with the Adobe Flash Player.
Link: http://archos-apps-installer.googlecode.com/files/gAppsInstaller_v5-final.apk
Top Insignia Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Insignia Tablet and eReader Expert? Answer questions, earn points and help others
