The dryer will work but won't stop running
Good Morning Daniela,
I see that you are having trouble with your Frigidaire Affinity gas dryer to stop running. It sounds to me like there could be something going on with the actual control panel on your appliance. It could also be something to do with the door latching mechanism. I would suggest contacting your local authorized technician to be sure that is what is causing the issue.
-Best Regards-
WP
Item # 686172
In Stock
The blower wheel draws air through the dryer
and pushes the air out the vent. If the dryer won't stop, the blower
wheel may not be spinning properly, which reduces the air flow. Check to
see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video
$23.40
Quantity:
Item # 528055
In Stock
The heating element assembly warms the air
before the air enters the dryer drum. If the dryer won't stop, it may be
because the heating element assembly isn't working - which greatly
increases the drying time. Check the heating element for continuity.
Part Testing Video
$91.05
Quantity:
Item # 2659
In Stock
Dryer sheets and fabric softener can leave a
residue on the lint filter, reducing the air flow. If the dryer won't
stop, check to be sure air can flow freely, clean the filter as needed.
$38.95
Quantity:
Item # 469522
Although not as common, if the dryer won't
stop it may be because the moisture sensor is either defective or coated
with fabric softener. Clean the moisture sensor contacts inside the
dryer and th
