Konica 7155 gives an error code sc46-14
Replace the roller and clutches
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
SOURCE: Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
SOURCE: Copier Failure Konica
Note: For safety used please turn off the machine first.
- Check and clean all sensor if there are no obvious paper pieces stuck or dusty.
- Check and clean the Roller if you see dusty.
SOURCE: re: konica 7821 n
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: konica minalota 210 error code detials can
If you are asking about a C0 210 code on a Minolta Di183 then this code means there has been a abnormal image transfer voltage error. The service manual says "the image transfer voltage remains more than 100V for a continuous given period of time while the PC drum remains stationary".
Have you opened/closed the front door or turned the machine off then back on to reset the code and see if it returns?
27 years working on Minolta copiers and I have never seen this code on this model of machine before so hopefully it will reset. If not you will need to call for service on the machine.
Good Luck and Thank You for using Fixya.
