Have a gas Jenn Air cooktop where the flame flares up sporadically normally while cooking on that particular eye.
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: Jenn Air Cooktop Burners Won't Ignite
The orifices may be dirty. They can usually be cleaned out with a safety pin.
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
SOURCE: Jenn-Air JGD8130 Gas Cooktop will not ignite
I just ordered one of these---sounds like people are not happy with this model---please get me more info
SOURCE: cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
SOURCE: Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
