Lost set up wizard
SOURCE: Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
burn disk reset router unplug power. plug ethernet cord to laptop to router type 192.168.1.1. then admin
admin
now you should be forwarded to router setup check settings hit save then go wireless security choose wpa2 choose password has to be a word atleast 8 letters long plus numbers
SOURCE: cannot finish installing
Do you have a wireless adapter..Linksys? If you have a wireless Linksys router, then get the wireless adapter that plugs into the back of your comp in a USB port.. Download information from the CD that is included..Go into your base unit(Linksys router). Configure it according to CD instructions. You should be up and running.Remember..When it asks for a password and username..Leave username blank and default password is "admin".You can always change password and username later for your protection. Type in 192.168.1.1 or 192.168.2.1 to access router base information in your address bar.
Just remember to download the CD for the router first ..Then download the CD for the adapter before plugging the adapter into a designated USB port.. The CD will advise you when to insert the adapter into a port.. Pretty self explanatory.. Good luck with that !!!
SOURCE: lost installation cd cant connect to wireless
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless
network then make sure that you are typing the
correct network key.
Click here for more information about routers and
network
SOURCE: error 311 no wired adapter detected
For that right click on my computer icon then click on property then hardware-<device manager.
Then you can see all driver list click on network adapter and enable it.
You can configure your router without disk too.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: When I run the set
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
