SOURCE: Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
SOURCE: TOSHIBA MODEL MV13M2 NO MANUAL, NO FACTORY REMOTE
HI
Yes you can set the menu function if have menu button is there!
Thanks!
SOURCE: My remote will not work
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
SOURCE: how do you get to the set up menu w/out a remote
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
SOURCE: TOSHIBA 19av600u 19
A few questions first:
Yes the your Toshiba has a 15 Pin VGA input on the back I/O panel.
Are you using a 15 Pin VGA male to male connection between your TV and Computer.
Is your Computer a
1) laptop or a
2) desktop
The highest PC resolution this TV will handle is 1280x1024 @ 60 hz.
Here is a web site below with your TV's Specs:
http://www.crutchfield.ca/ProductDetails.asp?ProductCode=05219AV600&Show=ExtInfo
If you are trying to use a HDMI cable then PC is not the selection you wish to select but the HDMI input is.
Blessings always,
A/V Media Tech Guy
