The belt that runs the cutting blades has come off and i need to see a diagram toloop it correctly through all the wheels.
Jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
The belt that runs the blade is securely attached and I even stuck a stick in the blade while it was running to see if it stopped when encountering grass, but the blade almost yanked the stick out of my hand. I took the blade off and sharpened it but still doesn't cut grass.
