ATTACHING CROSSOVER TO SPEAKER WITH PROPER WIRE. CODING
SOURCE: i would like a wiring diagram for peavey pro 15
Here is their support page if it helps:http://www.peavey.com/support/ Also try this link:http://forums.peavey.com/
SOURCE: whats the wattage of the bulb used in peavey sp2
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
SOURCE: could u please send me a circuit diagram of Peavey
Here is a link to forum that someone has posted the soundguard protection circuit down the page:
http://forums.peavey.com/viewtopic.php?f=26&t=2168&view=previous
The 1156 lamp MAY have slightly different shapes but is an automotive lamp. If the bulb is blown, the polyswitch fuse is likely blown as well.
SOURCE: I have a Peavey PV 115 Speaker...The horn works
Check the resistance across the woofer connection points. Using an ohmmeter, you should se around 6 to 8 ohms. If there is no continuity, you have a blown speaker.
SOURCE: I need a color coded
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
