Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
A
Amanda Lay Posted on Mar 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F3E3 Meat probe Shorted
Just purchased this oven & this code comes up & tells me I can't use it! F3E3 Meat Probe Shorted. Well, the meat probe wasn't even in there. I put it in & still comes up w/ this error
Jhune Obias
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 148 Answers
  • Posted on Mar 22, 2014
Jhune Obias
Expert
Level 2:
Cheetah:
Answers
148
Questions
0
Helped
33743
Points
340
Faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
4 Related Answers
captain801
Simon
  • 23 Answers
  • Posted on Dec 25, 2011
SOURCE: How do you use the meat probe
Insert the probe into the center of the meat, in an area where it's likely to cook the slowest. Anything above 63 degrees celcius is considered safe for consumption.
Anonymous
  • 5 Answers
  • Posted on Oct 26, 2009
SOURCE: My Jenn Air oven is asking me to remove the meat
you could have a bad probe receptacle. Or a board problem. Kill power to oven, wait 10 min, cross your fingers and restore power.
pro appl ser
  • 75 Answers
  • Posted on Jan 10, 2011
SOURCE: meat probe broken. I turned the oven temp up too
you can just change the probe. get the model number and i can get you a part number
Anonymous
  • 1902 Answers
  • Posted on Feb 04, 2011
SOURCE: shuts nd wants meat probe
Hello & Welcome to FixYa
The problem is either with the sensor or the electronic control that has gone bad and needs replacement. You can take out the sensor and check it with a voltmeter...should read around 1100 ohms. Please get back to me if you have any other questions.
Kevin
What is the meaning of f8 error code
shorted meat probe:
the problem could be with the probe, or probe circuit. check the probe look for pinched wire or condensation on the probe receptacle
Dec 14, 2015 • Ovens
Error code f3e3
Swap the leads on the probe jack terminals at the main board
2answers
Whirlpool Oven has error code f4-e411
F4 Shorted oven temperature sensor Replace oven temperature sensor
Jun 11, 2011 • Ovens
1helpful
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
2answers
Could you tell me what error code 003 is for a zanussi zbd 903 built in double oven
This code is displayed when the user attempts to restart the appliance after an
error code 001 or 002
- Safety circuit malfunction
001 if the meat probe is open circuit or the temp of the food is over 100deg c
002 is if the meat probe is short(closed) circuit hope this helps
3helpful
2answers
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
Has an f-8 on dislay oven won't work
F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle
1helpful
My oven is stuck in probe mode and will not cancel.. what should i do
Measure the resistance of the meat probe on the K-ohm setting. If it's open, then the probe is bad. I'm not finding a spec on the resistance but it should be something in the K-ohm range.
Next stop is to check the meat probe socket. May be gunked up with condensed grease or whatever. Sometimes a light schmear is all it takes to flake it out. Then check continuity from each leg of the meat probe socket back to the ERC, where the meat probe harness connects.
Mar 06, 2010 • Ovens
2answers
What does F4 mean, oven shuts off and code comes up?
The code indicates an Open or shorted oven temperature sensor. Solution is replace oven temperature sensor Here's a link to a short tutorial on how to make the repair... http://www.applianceaid.com/changingoventempsensor.html
2helpful
3answers
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
