When i try to install the hp color laserjet cm2320fxi mfp the xp window asks me the pdl_common . so how can i install the pdl_common
SOURCE: color laserjet cm1015 mfp
Check your network configuration and the ip
addresses. Turn off your printer and your notebook then turn on the
printer first and then the notebook. Sometimes, this is caused by the
ip address that doesn't match in your machine and your printer.
You
might, as well, try to check the printer properties and go to PORT and
check what the ip address of the printer is and it has a check mark.
Compare both ip on the properties and the actual ip of the printer.
Another option is to add port in the printer properties, this should resolve the issue. Thanks.
SOURCE: after trying to install HP
Go to HP Website and download the software from there. It's probably more up to date than the CD.
SOURCE: I have a HP Laserjet
hi..
You mean hp laserjet 9050 multi function printer right..
Click link below to get yr software technical reference
http://www.4shared.com/document/nwbyL0Lb/HpLaserjet_9050_software_techn.html
To download driver and firmware CLICK HERE then select your language
CLICK HERE to guided troubleshooting
Product Manual CLICK HERE
regards
multilinkent
contect me for furture problems
SOURCE: loss my drivers for HP Laserjet M1005 mfp
If you go to H.P's website and go to support imput that you need drivers for your laserjet m1005 mfp. and you will either be able to down load it right away or they will send you an e-mail with it or a link to retrieve one..Good Luck
