Deleting old Main Greeting and recording a new Main Greeting.
Hi Becky,
I have instructions for you that includes in the manual on page 18 how to change the greeting on your phone. Hope it helps.
http://pdf.textfiles.com/manuals/TELECOM-S-Z/Samsung%20SVMI%208%20User%20Guide.pdf
SOURCE: would like to record greeting
Here is a link to the instruction manual (5.06MB): http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2. Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep. Sample Outgoing Announcement Hi, this is (use your name here), I can?t answer the phone right now, so please leave your name, number and a brief message after the tone, and I?ll get back to you. Thanks. Reviewing Announcement ? Press and release the announce button to play your outgoing announcement.
SOURCE: how to chg a norstar mailbox from 'General Delivery' to 'User'
check under the mailbox set up ( where you created it) for that extension that the extension number of that phone is on that mailbox> in other words, you could create mailbox 221, but assign it to 222. The Gen Delivery box is 100 which is the catch all for transfers that cannot be completed.
SOURCE: how do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
SOURCE: Nortstar M7324
In order to record an alternate greeting, you sign into your voicemail. Select Admin, Select Greet, Select Choose (and select which greeting you would like to use eg..Prime or Alt) Once you select the greeting. The voicemail is set to use that greeting. To record that greeting, go back into Admin, Select Greet, Select Rec, and record and save your greeting.
SOURCE: how to remove the old corporate greeting in T7316 Nortel?
Press Feature 983 enter admin password
press AA
press Grtg
press Grtg again
press 1 then ok.
Greeting 1 is usually for day and 2 is usually for night depending on the tech who set it up.
