I've tried everything I can think of: 1. Reset PS3 video by holding the power button method 2. Tested with multiple known working HDMI cables 3. Tested on a second TV (LG) and it works fine 4. Tested a second PS3 on the Dynex and it works fine as well.
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Press and hold the power button until
the systems shuts off. (wait 2 seconds)
Press and hold the power button again
until you here 3 beeps. Let go.
It should ask you to connect your
controller via usb and press the PS button in
the middle of your controller. There
will be a menu with 6 options. Try 1-5.
