Question about Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
My computer doesn't recognize my hooked in to 3.0 USB port on my ASUS laptop, initialized, SATA 2TG internal drive that's within an external case.
Does it need to have a Drive name?? & How do I give a drive name to a USB external SATA storage drive that has been initialized??
    Problem Solver:
  • 11 Answers
Depends on the operating system but normally if you can see the drive in pc manager (right click mycomputer icon, select manage, select disk management in windows) if the drive is listed then format it and allow automatic drive letter assingment
Posted on Mar 24, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Posted on Mar 08, 2009
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: Trying to format a 500GB HDD at full capacity
sounds like the SATA - PATA converter doesn't accomodate for a 48 bit LBA (to handle disks of more than 137 GB)
you need to get the correct converter, as this one is not compatible, you should be able to return the converter as not fit for purpose (needs LBA 48bit).
Posted on Oct 11, 2007
zzptichka
zzptichka
  • 95 Answers
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Posted on Nov 30, 2008
Anonymous
SOURCE: COMPUTER COULD NOT DETECT WDC WDG1U5000N WHEN INSTALLED
Had the same problem...tried everything with no results. In desperation, I grabbed a different USB cord, plugged it into the drive and the laptop and VIOLA! my laptop could see it again! Maybe this will help someone. Cheers!
Posted on Apr 06, 2009
Anonymous
  • 51 Answers
SOURCE: External Sata Drive no longer recognized
My friend it sounds like your hard drive. I know thats not what you want to hear. But don't worry there is hope! You can have the data retrieved from your hard drive by using this online company which I highly recommend:
http://www.gillware.com/
Posted on Aug 31, 2009
WD7500KMVV external sata ata drive powering on but windows doesn't recognize it. Connected via USB.
If it is "brand-new", then it needs to be "initialized".
Click the Windows "Start" button
Right-button click on "Computer"
Choose "Manage"
Choose "Disk Management"
You'll see a view of all the disk-drives.
Select the new W.D. drive.
Right-button click on it, and choose "Initialize".
Apr 15, 2014 | Western Digital WD7500KMVV 750GB 5400 RPM...
Can I connect a WD1600 Hard Disk via USB connector for external drive?
You need to purchase an USB hard drive adapter case and install your hard disk inside this case. Take your hard drive with you when you got to a computer shop so you will get the correct IDE or SATA USB adapter case.
Mar 26, 2013 | Computers & Internet
Hi my toshiba mk3265gsx hard disk is detect as a usb device as external, but not work and has no partition no bad disk and can not be able to work with this, it is just a usb device with no action (this...
With a brand new drive, you have to initiate your drive using the Disk Management tool in Windows.
To do this, go to Start-->Control Panel --> Administrative Tools --> Computer Management. Then select Disk Management from the menu on the left. Once everything is loaded up, you should see your new drive in the list of volumes on your computer. You'll have to right click on it and click Initialize Disk. Once you've initialized it, you'll have to formate the drive and create partitions.
If you need anymore help, let me know.
Mar 25, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I want a much larger drive to fit my notebook
It looks like your current drive is a 80GB 2.5" EIDE.
The maximum you could easily get is probably 320GB for $90-100.
The price is high as SATA drives are now the standard.
Have you considered getting a 2.5" 500GB external drive, connected by USB.
The external 2.5" drives are powered off the USB and need no other connections
It would be cheaper and give you more storage.
You wouldn't have the difficulty of opening up your laptop, and if it's working OK now it's best to leave it that way.
Jan 30, 2011 | Seagate Momentus 5400.3 Hard Drive
I cannot connect my external hard drive through the sata port
Install the external hard drive into an USB hard drive adapter case. You can then connect this into the Toshiba's USB port. The Toshiba will see this as an external storage device.
Jan 08, 2011 | Toshiba Satellite Pro M300-S1002X Notebook
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
How do i get a new hard drive to recocgnize the external drive
Connect the external storage
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management
Check to see if there is a "healthy" partition covering the disk-space of the external storage device.
Jun 24, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Aug 10, 2009 | Western Digital My Book Home Edition 500...
I need to add a hard drive to my HP a1220n Pavilion for Photoshop and other Graphic programs. How can I do it if there is no available slot? Please help.
A desktop PC would normally have capacity for 4 IDE devices such as 1 CD/DVD, 3 HDs or any combination limited to a total of 4. Additionally, most current PCs have 2 SATA connection points. If for some reason all are occupied and hence your post "no available slot", you may want to consider using an external storage device attached via any USB port of your PC.
Hope this be of some help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | HP Pavilion a1220n (A1220NED904AA) PC...
Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA Logo
88 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
ChinthakaJ
ChinthakaJ
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
